john deere 120 implement control valve?
3 replies to this topic
#1 oliver2655 OFFLINE
oliver2655
  • 37 Thanks
  • 82 posts
Posted December 28, 2014 - 12:48 PM
i have a john deere 120 that drives okay forward but when in reverse the hydrostat seems to cut in and out and surge. fluid level is fine. has anyone came across this problem? i was told my problem is the implement control valve? where is this valve located?
#2 Trav1s ONLINE
Trav1s
  • 3,571 Thanks
  • 4,544 posts
Posted December 28, 2014 - 03:28 PM
More than likely one of the free wheel check valves located below the seat pan on top of the pump is stuck open.  I faced a similar problem with my 120 when I did the restoration work.  Do you have a service manual?
#3 oliver2655 OFFLINE
oliver2655
  • 37 Thanks
  • 82 posts
Posted December 28, 2014 - 08:04 PM
are those check valves repairable? or does it just have to be replaced?
#4 Trav1s ONLINE
Trav1s
  • 3,571 Thanks
  • 4,544 posts
Posted December 29, 2014 - 08:24 AM
They are repairable - generally people soak the little button on top with PB Blaster and let them sit.  I worked them up and down with a screwdriver until the moved smoothly and freely.  Some also pull the valves and soak them on the bench.
