H14 Hydro Filter Canister
i need one
27 replies to this topic
#1 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted December 27, 2014 - 06:30 PM
Ive been looking all over for a Hydro filter p# 1727231.  I currently have a Fram on mine but cant tell the number because its worn off.  Mine is leaking really bad on the left side or locking diff side.  so bad that it leaves a puddle on top of the trans and runs down the side and on the ground. Its not leaking at the the fitting that screws on but right where it goes into the canister at what looks to be a hex end mounted on the filter that you might be able to put a wrench on????    HELP!!!
  • blackjackjakexxix, sacsr, boyscout862 and 2 others have said thanks
#2 blackjackjakexxix ONLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3727 Thanks
  • 2367 posts
Posted December 27, 2014 - 07:25 PM
Those are NLA,if you get lucky enough to find one there pretty pricey,you maybe better off to look for the other style set up that Bolens used,it uses a screw on filter,
  • Nascar3244888, superaben and MyBolens1053 have said thanks
#3 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted December 27, 2014 - 08:46 PM
This style is new to me, I dont have much experience with hydros, what parts from what tractors should i look for????
  • MyBolens1053 said thank you
#4 blackjackjakexxix ONLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3727 Thanks
  • 2367 posts
Posted December 27, 2014 - 10:21 PM
Let me take a look through my books to make sure I give you the right info
  • Nascar3244888, boyscout862 and MyBolens1053 have said thanks
#5 EricFromPa ONLINE
EricFromPa
    Fixer of Broken junk
  • 6887 Thanks
  • 4614 posts
Posted December 27, 2014 - 11:39 PM
Something like This might work.
http://www.ebay.com/...=item2c93d92f33
or this without the hard lines.Little cheaper.
http://www.ebay.com/...=item2c8be3ab69
  • Nascar3244888 said thank you
#6 MyBolens1053 OFFLINE
MyBolens1053
  • 689 Thanks
  • 602 posts
  • Location: Martinsburg, WV (surrounded by Apple Orchards)
Posted December 28, 2014 - 12:00 AM
The inline canister filter was introduced on the model H-14 (1456) with serial #0200101 and up. I did find that Fram's Part # is P-1659 and is discontinued.
#7 MyBolens1053 OFFLINE
MyBolens1053
  • 689 Thanks
  • 602 posts
Posted December 28, 2014 - 12:11 AM
You may also cross reference the Fram # in the Ford brand tractors. I read this post in another archived site.
"Ford used it on their garden tractors also from 1972-1983. Fram P-1659."
#8 KennyP OFFLINE
  • 53206 Thanks
  • 53318 posts
Posted December 28, 2014 - 05:05 AM
That inline filter through New Holland will cost you $117.51 + shipping. Part # is 87346701. I'd be changing to a screw-on style!
  • Nascar3244888, sacsr and Sawdust have said thanks
#9 blackjackjakexxix ONLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3727 Thanks
  • 2367 posts
Posted December 28, 2014 - 09:58 AM
Ok, ya looks like some of the H-14's had the screw on type as well as the H-16,thats the style I would go with,right now I don't have anything to help you,maybe another member here can help you out
#10 Tspeyfly OFFLINE
Tspeyfly
  • 9 Thanks
  • 16 posts
Posted December 28, 2014 - 10:21 AM
Hello All
I've a H15 with the screw on mount and hard lines plumed in.
Would I need anything besides the lines to swap over to a H16 with stock canister?
Thank's in advance,
Thomas
#11 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted December 28, 2014 - 10:23 AM
Do you mean an H16? H15 dosen't exist
The one in your picture is a gear driven Tubeframe.....
#12 blackjackjakexxix ONLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3727 Thanks
  • 2367 posts
Posted December 28, 2014 - 01:24 PM
I think your 1556 is also going to have the same filter set up as the H-16,no need to change anything
Edited by blackjackjakexxix, December 28, 2014 - 01:24 PM.
#13 Nascar3244888 OFFLINE
Nascar3244888
  • 332 Thanks
  • 628 posts
Posted December 28, 2014 - 06:36 PM
got the hydro filter off today with no problems, since the filter is no longer available i feel like i have nothing to loose, so i used some black silicone rtv, to try and seal up the leak i have between the nut looking fitting on the one side and the actual side of the canister. I used some gasoline to clean the area before applying the silicone. Im going to leave it sit a couple days and then maybe try it out....hopefully it will work..
#14 bhts OFFLINE
bhts
    Bob's Lawn and Garden LLC
  • 1493 Thanks
  • 2181 posts
Posted December 28, 2014 - 07:54 PM
I have a screw on mount for $10.00 if you want to change it over. I also have the filters new for the screw on type. You will need to mount it and run new hoses if yours are to short.
  • Nascar3244888 and MyBolens1053 have said thanks
#15 blackjackjakexxix ONLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3727 Thanks
  • 2367 posts
Posted December 28, 2014 - 08:11 PM
If the filter was in that bad of shape to leak,its probably not doing much good,you really need to replace the filter one way or the other,IMO
