1968 Custom 10 XL Tecumseh Specification Number?
9 replies to this topic
#1 LStrodtman OFFLINE
LStrodtman
  • 7 posts
Posted December 27, 2014 - 03:12 PM
Hello, all
I recently latched onto the 1968 Custom 10 XL that my dad bought back in the 80's for his rental house.  Over the course of time, the machine has fallen into serious disrepair, and I'd like to get it back fighting shape.  Before going too far, though, I need to obtain a carburetor body (ear broken off in a bad way) and ignition components.
The ignition parts are mostly under the flywheel and are battered to death; my guess is they were loose and someone cranked the engine over.  I keep reading the parts for these engines are NLA, and that switching over to some Hall Effect system is the cat's meow.  I figured I'd ask here to get the low-down from folks who may have had the same problem locating parts, or even someone who had used the fancy new systems.
In my shopping around for a replacement HH100 carburetor, I found a lot listed with either no application listed, or being listed for a snow blower.  While I normally would think it wouldn't matter, the fact a snow blower only operates in cold weather got me thinking my engine may not get along for very long if used on a 102 degree July day.  The Tecumseh manual's cross reference chart indicates that my engine is a HH100, but it doesn't list the Specification Number I need to order parts!    I tried getting parts/replacement carb using the Lauson "466" number and crossing it to a Tecumseh part number, but that led me nowhere.  Truth be told, I don't know that the carburetor I have is correct.  Can you all help me out with what Tecumseh part numbers I can use to find parts for my machine?
Tractor Data
917.25260  Serial:  4099
Engine Data
Model:  143.589022
Serial:  8193 08079
Carburetor Data
Lauson: 466  4M19  Has a "38" cast into it.
Thanks for looking!
-Loren
#2 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted December 27, 2014 - 06:38 PM
Loren, your HH100 model number is a HH100-115098B.
That model number does not come up online, so I'll dig out the Tecumseh book and get some part numbers for you this evening.
Carburetors are fairly easy to find, just not always in good shape.  You have to be discriminatory.
Do you have a condenser and point ignition system or the big solid state box above the flywheel?  If you have condenser and points, there is no good way to redo the ignition without replacing the damaged coil and similar parts.  If you have solid state ignition, there are options.
Tell me what is under the flywheel.  Is it a coil and charging coils for the electrical or just a stator?
Ben W.
  • LStrodtman and MH81 have said thanks
#3 LStrodtman OFFLINE
LStrodtman
  • 7 posts
Posted December 27, 2014 - 09:07 PM
This mess is what I have! I'm new to this system, so I dont know why the thing needs two coils and a GM HEI module...
http://www.ebay.com/...=item3a9d361d61
#4 MH81 OFFLINE
Posted December 27, 2014 - 09:35 PM
Tecumseh used no less than three different ways to make a spark on the hh100.
Lets start with step one: which does the module above the flywheel most look like?
  • LStrodtman and KennyP have said thanks
#5 TAHOE OFFLINE
TAHOE
  • 7,975 Thanks
  • 5,674 posts
Posted December 28, 2014 - 07:35 AM
Alan, he has the early style SSI system #3
Loren, if you want a direct replacement, pretty much plug and pay, then check out Dale Colvert's Overnight Solutions ignition, it's basically a bolt on, not sure if he has the charge coil thought hat generates the juice which is you ring part under the flywheel.
If that doesn't light your fancy, check out Ed Stoller's engines and magnets site or even BRian Millers garden tractor pulling tips.
You can click the link in my sig, it's for a 16 hp Overhead motor, but same principle and I have other links inside my thread.
For the carb, the 10 Hp Tec came mostly with the Walbro LME carb, at least my 68 12 Hp did. You may get lucky to find a used one somewhere. Last resort, a  carb from a 8Hp Kohler will bolt on and run that motor well, you just have to make new throttle/choke linkages.
  • LStrodtman said thank you
#6 MH81 OFFLINE
Posted December 28, 2014 - 08:47 AM
Marty,
I didnt (and still don't) see where that has been confirmed. I was just trying to verify what exactly we are dealing with.
If he does have number three, the flywheel may not have the pickup pins. If no pins, then the trigger is under the flywheel and the engines and magnets stuff won't work without the pins, last I knew the overnight solution needs them too.
Your solution may not need the pins, but it does need the pickup magnet.
If he doesn't have the pins, it will mean some additional work, just making sure which way to help direct him.
#7 LStrodtman OFFLINE
LStrodtman
  • 7 posts
Posted December 28, 2014 - 11:34 AM
Fellows,
My coil most resembles number three, and the high voltage lead is cut clear down to the wire. Ive checked out the Overnight Solutions website, and will look into the others as well to learn more about what is available. I like the idea of basically a bolt on system! I'll look again, but I dont believe my flywheel has pins. There are magnet(s) inside the flywheel. If I need to add pins to get her running, I have a machinest nearby.
Thanks, everyone, for the help.
Tahoe, I will check out your ssi photos as soon as I post this!
-Loren
#8 MH81 OFFLINE
Posted December 28, 2014 - 01:39 PM
Yes, you will need to add the pins or a magnet like Tahoe did.
I believe his magnet is at 17 degrees before TDC, verify that, but that's where the short pin should be on the flywheel.
#9 drbish ONLINE
drbish
    Collecter
  • 1,557 Thanks
  • 1,361 posts
Posted December 29, 2014 - 07:56 AM
Fellows,
-Loren
Loren,
 you might  want to check on this craigslist ad
http://columbia.crai...4823114086.html
or this complete engine,you might get him to ship
http://charlotte.cra...4811992432.html
Edited by drbish, December 29, 2014 - 08:00 AM.
#10 TAHOE OFFLINE
TAHOE
  • 7,975 Thanks
  • 5,674 posts
Posted December 29, 2014 - 08:53 AM
Marty,
When I made my statement, I went off the evilbay link Loren posted thus stating he had the early version.
Loren, unless you have the know how and parts connections, whatever ignition system you go with, it will run $150. or more. Dale does have a system that will convert your engine over, but I see that it will make it a battery-coil based system thus still needing some type of charging system. The newer SSI modules on the overhead valve motors are a self sufficient system once running, battery is only needed for starting motor. Most conversion though convert that system to a battery-coil thus needing charging system. I am relatively unfamiliar with the older systems, most of my work/research has surrounded the newer style SSI l modules.
The guy who designed my system figured the OH120/140/160 had the advance timing pin set at around 23-25*. I can measure pins, but guess that won't help much since I have a pin for TDC as reference, not sure how to relate that to a non pinned flywheel.
