Cub Exhaust elbow
17 replies to this topic
#1 Coventry Plumber OFFLINE
Coventry Plumber
  • 1,087 Thanks
  • 589 posts
Posted December 27, 2014 - 08:20 AM
I need help finding a exhaust elbow for my Cub Cadet 128 kohler. I am at the assembly pointing my restore and I'd like to get a new one if possible but I don't know where to find one. My current one has threads that are severely worn so I'd rather start new and never have to replace it again. Any help will be appreciated.
#2 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted December 27, 2014 - 08:22 AM
Is it a regular NPT elbow that is on there now?
  • Coventry Plumber said thank you
#3 Coventry Plumber OFFLINE
Coventry Plumber
  • 1,087 Thanks
  • 589 posts
Posted December 27, 2014 - 08:28 AM
Yes I believe so , I had put a steel plug in during restore. Engine threads are good but elbow threads are shot.
#4 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted December 27, 2014 - 08:37 AM
I have always gone to the hardware store and bought the NPT pipe I needed to make the exhaust how I wanted it or to keep it stock. Do you still have the locking collar from the old pipe? The locking collar is the only thing I am not sure on sourcing. I don't know if the 12hp Kohler has a reducer in the head. My Kohler 16hp does. The pipe thread size is either 1" or 1 1/4" NPT. You can take your old elbow with to the hardware store and match it up.
  • superaben and Coventry Plumber have said thanks
#5 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
I know what piece you are talking about.  One side has male NPT, the other side is just plain pipe.  It is a gentle 90 degree elbow.
It is a Kohler part.  It is still available new for $116!  I've sold two, they are common pieces to need a little love, but not cheap.
Joe's Outdoor Power sells them used for about $20 if I remember right.
Ben W.
  • NUTNDUN, Bolens 1000, KennyP and 1 other said thanks
#6 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted December 27, 2014 - 08:40 AM
Ben W.
That is good info to know Ben. I didn't realize they had a special piece that was factory. Used one wouldn't be bad but I don't think I could justify a new one. None of the Kohlers I have ever worked on had anything different other than regular NPT pipe.
#7 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
The collars are just a thick version of a conduit nut.  I use conduit nuts and have never had a problem.  Kohler will ream you for $10 to buy a new one.
Ben W.
  • NUTNDUN, Sawdust and Coventry Plumber have said thanks
#8 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted December 27, 2014 - 08:42 AM
Ben W.
I will definitely keep the conduit nut in mind. I thought they were too thin and would warp from the heat but that is great they work.
#9 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted December 27, 2014 - 08:43 AM
That price jumped here recently.  I sold them for $50 last year.  A price jump like that means that it will probably go NLA before 2015 is over.
It looks like John Deere and Cub Cadet are the only specs that use that special pipe.  It is part number 235692.
Ben W.
  • NUTNDUN and Bolens 1000 have said thanks
#10 cootertom OFFLINE
cootertom
  • 1,575 Thanks
  • 822 posts
Posted December 27, 2014 - 09:08 AM
Go to a good electrical parts house and they carry a heavier locknut for rigid conduit. Lowe's usually
has only the light weight locknuts.
Tom
#11 Grumpy ONLINE
Grumpy
  • 721 Thanks
  • 617 posts
Posted December 27, 2014 - 09:44 AM
I think I have one, I will look tomorrow. We are still doing Christmas today.
#12 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted December 27, 2014 - 10:10 AM
Tom
Yes, you are right.  I should have clarified.  Lowe's (and even most Ace stores) carry a thinner stamped steel nut.  They do not hold up as well under exhaust heat.  A contractor supply store will have them, although you'll probably have to buy a box of 20 or so.
Ben W.
#13 Coventry Plumber OFFLINE
Coventry Plumber
  • 1,087 Thanks
  • 589 posts
Posted December 27, 2014 - 10:45 AM
Ben W.
Yes that is the pipe I'm looking for , mine is badly pitted and threads are almost gone, I still have the
Original lock nut. I'm trying to stay as close to original as possible but $100plus dollars I can't justify for it. This cub will have a easy life if I ever get it done. Thanks Tom
#14 cootertom OFFLINE
cootertom
  • 1,575 Thanks
  • 822 posts
Posted December 27, 2014 - 02:07 PM
I'll look when the kids leave. I may have one. If so I'll mail it to you.
#15 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,281 Thanks
  • 9,771 posts
Posted December 27, 2014 - 03:02 PM
This looks like something that could be replaced with conduit pipe.
Edited by LilysDad, December 27, 2014 - 03:03 PM.
