Hydraulics on Craftsman
3 replies to this topic
#1 charlesben12 OFFLINE
charlesben12
  • 4 posts
Posted March 02, 2011 - 04:05 AM
Would it be feasable to mount a hydraulic pump on a 2010 Craftsman GT and drive it off of the drive belt or is there a way to tap into the hydraulics on the transaxle. I have even considered a 12 volt unit like on snowplows. Any suggestions?
#2 NUTNDUN OFFLINE
  • 10,269 Thanks
Posted March 02, 2011 - 06:15 AM
I don't think you would be able to port anything off of the existing hydraulics because a lot of the newer stuff has sealed rears and you can't even add oil to them if they get low.
You could mount a pump to be driven off of a pulley, anything is possible if you have the capabilities to do some fab work. The electric hydro pump would be the quickest and probably the cheapest way.
  • charlesben12 said thank you
#3 Deck_Drive OFFLINE
Deck_Drive
    collector of sears
  • 96 Thanks
  • 348 posts
Posted March 07, 2011 - 08:31 AM
I would go with running the pump off the drive belt. Since your tractor is a hydrostatic is will have an "always running" drive belt. But it wouldnt have what we call live hydraulics. Meaning if you hit the clutch the hydro pump wont do anything.
#4 Alc ONLINE
  • 5,658 Thanks
  • 6,746 posts
Posted March 07, 2011 - 08:41 AM
Are you looking for something just to raise the deck or hitch ? My Mom's WH has an electric lift that was put on at the dealer , maybe that would work for you.
