Wanted
Need Carb
9 replies to this topic
#1 cootertom ONLINE
cootertom
  • 1,592 Thanks
  • 825 posts
Posted December 26, 2014 - 09:48 PM
Looking for a two piece flowjet carb for a Briggs model #142302 6 H.P. engine. If it can be rebuilt then it is fine. Not sure the one I have will ever break down for cleaning and rebuilding.
Thanks
#2 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted December 26, 2014 - 09:52 PM
the carb you need is a medium flow jet. They made them in three sizes, small med, and large. You orginal carb should have a special part on the end of the throttle shaft that you will need to operate the linkage properly.
  • Gtractor and superaben have said thanks
#3 jabelman OFFLINE
jabelman
  • 2,231 Thanks
  • 1,596 posts
Posted December 27, 2014 - 07:34 AM
Just remember they come apart only 1 way.
#4 cootertom ONLINE
cootertom
  • 1,592 Thanks
  • 825 posts
Posted December 27, 2014 - 08:01 AM
Right, the one I have is apart but rough condition. The venturi will not come out without stripping the threads off.
  • Lauber1 said thank you
#5 Lauber1 OFFLINE
Lauber1
    DB restorer
  • 3,477 Thanks
  • 2,811 posts
Posted December 27, 2014 - 10:41 AM
have you tried soaking it in lacquer thinner whole?
#6 jabelman OFFLINE
jabelman
  • 2,231 Thanks
  • 1,596 posts
Posted December 27, 2014 - 05:50 PM
Had that happen on one of mine once unfortunately it broke. They are fairly easy to find. I picked up 2 this year for 10bucks. Also you can get new upper and lower halves online fairly reasonable
Edited by jabelman, December 27, 2014 - 05:51 PM.
#7 cootertom ONLINE
cootertom
  • 1,592 Thanks
  • 825 posts
Posted January 01, 2015 - 09:43 AM
Soaked it in lacquer thinner and WD 40 with no luck. It turns about 1/4 turn then locks tight.
#8 MH81 OFFLINE
Posted January 01, 2015 - 12:26 PM
Acetone and ATF?
#9 cootertom ONLINE
cootertom
  • 1,592 Thanks
  • 825 posts
Posted January 03, 2015 - 09:32 AM
quote name="MH81" post="528371" timestamp="1420133179"]
Acetone and ATF?
[/quote]
Mixed together or either or one or the other?[
#10 KennyP ONLINE
  • 38,424 Thanks
  • 45,958 posts
Posted January 03, 2015 - 09:56 AM
A 50/50 mix of the acetone/ATF is very good for loosening rusted parts. Not sure how well it might work in your situation for corrosion due to 2 dissimilar metals. But might be worth a try!
