I'm at it again! Another Bolens Restoration underway!
41 replies to this topic
#16 IamSherwood OFFLINE
  • 8,390 Thanks
Posted December 25, 2014 - 06:34 PM
Looking forward to following along on this resto.
Thanks for starting the thread.
That's one of my favorite looking tractors.
I gotta find myself one some day.
#17 wilberj OFFLINE
wilberj
  • 4,991 Thanks
  • 5,590 posts
Posted December 25, 2014 - 07:54 PM
O look a 58 I need one of those Brian just ship it to me I would only need to find two more to have all the years. :D
Cant wait to see her all done up.
  • Bolens 1000 said thank you
#18 Cat385B ONLINE
    HAZMAT CAT
  • 13,782 Thanks
  • 9,921 posts
Posted December 25, 2014 - 09:35 PM
WTH? What happened to letting us pick?
Was anyone consulted with? George? The UPS guy? Magic 8-Ball?
#19 Bolens 1000 ONLINE
  • 14,928 Thanks
  • 18,113 posts
Posted December 26, 2014 - 09:18 AM
I was staring at it in the garage and just started taking thinks apart :D
#20 Cat385B ONLINE
    HAZMAT CAT
  • 13,782 Thanks
  • 9,921 posts
Posted December 26, 2014 - 09:20 AM
OK, I can get onboard with that.  :thumbs:
#21 Kfs35 OFFLINE
Kfs35
  • 408 Thanks
  • 416 posts
Posted December 28, 2014 - 09:55 PM
Looks like a good start. I'll be watching this one.
#22 chieffan ONLINE
  • 9,625 Thanks
  • 6,437 posts
Posted December 29, 2014 - 11:56 AM
What size saw blade is that"  Thinking of building a small buzz saw for a Gardener.  I was thinking of using a 12" rip blade for a miter saw?  A larger blade would have more teeth and turn faster on the outside.
Edited by chieffan, December 29, 2014 - 11:58 AM.
#23 Bolens 1000 ONLINE
  • 14,928 Thanks
  • 18,113 posts
Posted December 29, 2014 - 12:35 PM
I think its around 20''
#24 chieffan ONLINE
  • 9,625 Thanks
  • 6,437 posts
Posted December 29, 2014 - 01:50 PM
Thanks.  That is a good sized blade for that size machine.  Most full size blades around here run in the 28 to 36" size.  30" is the most common, depending on many times they have been filed.
#25 1967bolens collector OFFLINE
    Deceased
  • 654 Thanks
  • 1,441 posts
Posted December 31, 2014 - 07:22 PM
Its for the Versa-Matics
oh ok i thought itwas for a tube frame but thatvmakes more sence
#26 Bolens 1000 ONLINE
  • 14,928 Thanks
  • 18,113 posts
Posted January 02, 2015 - 05:23 PM
Little bit of an update today, got the engine apart and started to clean it up
Oil ring was stuck due to carbon deposits but other than that everything was to specs.
Looks like a set of rings,seals,gaskets and valve work and she'll be ready to go.
Also need to get a coil as this one was all cracked up and I'm not risking scratching the fresh paint when this is done to replace it if it decides to go bad :D
  • blackjackjakexxix, johndeereelfman and Gabriel have said thanks
#27 NUTNDUN OFFLINE
  • 10,336 Thanks
Posted January 02, 2015 - 05:57 PM
Brian,
What do you use to clean the block once you get it torn down and ready for paint?
#28 Bolens 1000 ONLINE
  • 14,928 Thanks
  • 18,113 posts
Posted January 02, 2015 - 06:06 PM
Brian,
I first use a degreaser on the block to remove the oil and sludge build up then I have a big selection of wire wheel tools of various sizes to get all the hard to reach parts of the block stripped of paint. I use a bigger wire wheel attached to a drill to do the larger spots.
Cleaning the engine block is probably my least favorite thing to do in a restoration, so much oil and so many small areas!
  • NUTNDUN, johndeereelfman, Sawdust and 1 other said thanks
#29 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted January 04, 2015 - 08:40 PM
I have set just like that (the one pictured above)!
#30 adamjd200 OFFLINE
adamjd200
  • 2,031 Thanks
  • 2,156 posts
Posted January 04, 2015 - 11:14 PM
I got the coil for my '59 RAM from Ebay seller Customchainsawparts, here's a link.http://www.ebay.com/...=item519666aa69
