Kohler K241 Engine Swap
kohler k241 engine swap
5 replies to this topic
#1 LBrush OFFLINE
LBrush
  • 19 Thanks
  • 26 posts
Posted December 23, 2014 - 06:10 PM
Will pretty much all K241 engines fit no matter what year, even from a different brand?
#2 lyall ONLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted December 23, 2014 - 06:17 PM
it depends on the crank - several different type of ends for the drive side
and the pan - some or flat bottom and some or not
what are you planning on putting it it
  • NUTNDUN and rustyoldjunk have said thanks
#3 NUTNDUN OFFLINE
  • 10,339 Thanks
Posted December 23, 2014 - 07:52 PM
As long as the crankshaft is the correct size you need and the oil pan is the same (which can be changed) it should work. You may have to swap out the dipstick for the oil level. Would definitely help the guys if they know what tractor you are putting it in.
  • Trav1s said thank you
#4 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted December 23, 2014 - 11:06 PM
You really need to know more than just that the engine you are looking at is a K241.  That isn't enough.
Like as has been mentioned, you could have the following things wrong and not even know it:
~Alternator setup (amperage, not just if you have it or not)
~Electric start or recoil start
~Crankshaft Length
~Crankshaft Diameter
~Flywheel design (for tractors with shaft drive)
~Governor setup (fixed, adjustable, or remote adjustable)
~Air cleaner mounting
~Cooling (sheetmetal) designs
~Fuel pump
There are great engine cross reference resources out there to help you.
Ben W.
#5 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,625 Thanks
  • 1,311 posts
Posted December 24, 2014 - 01:31 AM
Some pans won't interchange. You can't use a big deep style pan on most blocks that come with a small pan because the ears are not cast into those blocks to except the big pan. One exception is engines used in the 200 series JD's.
Edited by rustyoldjunk, December 24, 2014 - 01:31 AM.
  • lyall said thank you
#6 KennyP ONLINE
  • 38,231 Thanks
  • 45,866 posts
Posted December 24, 2014 - 06:08 AM
It takes some investigating to find if your donor will work. As others above have said, not all K241's are the same. The spec #'s will tell you if they will work in your situation. In the manuals section, locate the parts listing for your engine. That will tell you by spec # what your original engine came with. There is also a Crankshaft Reference Manual to show what the PTO ends are machined to.
I just went through this procedure for a K341 repower. My biggest issue with it all is that someone put a K241 flywheel shroud on it, so I didn't have the correct spec for the donor. A bit more looking around and I have found it will work, just have to change the pan. But that brings up whether the rod dipper stick will work with the new pan.
So it is not as easy as just buying an engine and bolting it in.
Also tagged with one or more of these keywords: kohler, k241, engine swap
