Ride-a-Matic Throttle Cable Replacement
1 reply to this topic
#1 Bolens 1000 OFFLINE
  • 14,983 Thanks
  • 18,140 posts
Posted December 23, 2014 - 05:31 PM
After about 2 years of searching I found a close replacement to the original cables
Only difference being the control lever sits higher up than the original does (See pic below)
This should not be a big deal as the travel distance is so small on these cables, full throttle will just be pushed a little farther forward compared to the originals.
New cable with a z bend will be included as well.
Replacement (left)  Old (Right)
Low Speed setting:
High Speed:
  • Texas Deere and Horse, Bruce Dorsi, Kfs35 and 2 others have said thanks
#2 Bolens 1000 OFFLINE
  • 14,983 Thanks
  • 18,140 posts
Posted January 03, 2015 - 12:59 PM
Now available!
Complete assembly's similar to the originals except the travel positions as described above.
$ 21.00 complete assembly
Or if you want to save the original control heads and just get new wire cut to install  its $ 7.00
