3-way Rotary switch face plate, Heat-Run-Start.
10 replies to this topic
#1 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted December 20, 2014 - 07:54 AM
Not the switch itself, I already have and in current use, the face plate indicating the position of the rotary lever.
For diesel engine, 3 way spring return lever type rotary switch like used n older Cat, JD and Dresser equipment.
Heat-Run-Start....or.... Glow-On-Start
#2 Cat385B ONLINE
    HAZMAT CAT
  • 13,782 Thanks
  • 9,921 posts
Posted December 20, 2014 - 08:11 AM
Is it 10-12-2 o'clock or 11-12-1? And does it have an indexing pin?
  • trowel said thank you
#3 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted December 20, 2014 - 08:34 AM
10-12-2 o-clock with index pin.
#4 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted December 20, 2014 - 09:40 AM
Jesse, something like the plate on the left?  If it is, I will send one to you.
Ben W.
  • OldBuzzard and trowel have said thanks
#5 OldBuzzard ONLINE
OldBuzzard
  • 6,987 Thanks
  • 4,784 posts
Posted December 20, 2014 - 10:04 AM
Ben W.
HEY!!!!!
That looks awful danged familiar.
You ain't partin out my HDT is you??????  :rolling:
  • Cat385B, superaben and fogler12538 have said thanks
#6 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted December 20, 2014 - 10:21 AM
HEY!!!!!
Sure.  I'm sending you 1/2 the profits.
:poke: :poke: :D
No, I bought a couple of those plates and switches at an auction a year ago.  It is the most common Japanese ignition switch.  They fit Kubota, some Hinomoto, some Yanmar, and Iseki.  A lot of the "engine supplier types" such as Kubota, Mitsubishi, Toyosha, etc would supply that switch to a manufacturer using the diesel engine.  That's how that switch probably ended up on your tractor.
Ben W.
  • Cat385B said thank you
#7 Cat385B ONLINE
    HAZMAT CAT
  • 13,782 Thanks
  • 9,921 posts
Posted December 20, 2014 - 11:25 AM
Jesse, the bezel Ben shows should have an inside diameter of 1" or 1&1/16". And it's a stick-on.
#8 Cat385B ONLINE
    HAZMAT CAT
  • 13,782 Thanks
  • 9,921 posts
Posted December 20, 2014 - 11:32 AM
HEY!!!!!
Crappola, that's funny right there.
#9 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted December 20, 2014 - 12:13 PM
Not all were stick on.  I'm used to seeing them just clamped down by the switch retaining nut.
Ben W.
  • trowel, Cat385B and mrmd have said thanks
#10 trowel OFFLINE
trowel
    Summer.
  • 4,823 Thanks
  • 4,533 posts
Posted December 20, 2014 - 07:05 PM
Ben W.
I am thinking it could work, send me one.
  • superaben said thank you
#11 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted December 20, 2014 - 07:06 PM
Will do.
Ben W.
