I think I have a useable Gas Tank for the 416S
416s fuel tank 416s
15 replies to this topic
#1 KennyP OFFLINE
  • 37,451 Thanks
  • 45,472 posts
Posted December 19, 2014 - 02:16 PM
I just purchased a fuel tank for my 416S. It came attached to this:
Here's the tank. It's needs a bit of plastic welding, but is in better shape than the one I have.
I did get the engine to fire off, though briefly! May have a replacement for the Ford! WooHoo!!!!! I will have some parts for sale as I do not plan to get it running again!
  • olcowhand, MH81, boyscout862 and 3 others have said thanks
#2 olcowhand ONLINE
  • 40,354 Thanks
  • 31,172 posts
Posted December 19, 2014 - 03:25 PM
Not a bad parts machine!  Used to I'd wanna fix up one like that....but I'm past that at the moment.
#3 KennyP OFFLINE
  • 37,451 Thanks
  • 45,472 posts
Posted December 19, 2014 - 03:36 PM
Me too! Plus I have been wanting to get the Ford going again. Miss my foot pedal hydro!
#4 KennyP OFFLINE
  • 37,451 Thanks
  • 45,472 posts
Posted December 19, 2014 - 04:22 PM
I wonder how this tractor would work with an Eaton 11 & Peerless 2500 under it? I have an extra one of those!
#5 OldAllis52 OFFLINE
OldAllis52
  • 273 Thanks
  • 160 posts
Posted December 19, 2014 - 06:13 PM
OH,I'm making my list and checking it twice! I see some things I need for mine!
#6 KennyP OFFLINE
  • 37,451 Thanks
  • 45,472 posts
Posted December 20, 2014 - 09:13 AM
I brought the tank and my little soldering/plastic welder in last night. Cut some strips off a piece of donor plastic, too. I just finished 'welding' the cracks back up. After a bit, I will test for leaks! Here's the pics.
Before:
After:
Other end Before:
After:
#7 Cat385B ONLINE
    HAZMAT CAT
  • 13,780 Thanks
  • 9,919 posts
Posted December 20, 2014 - 09:17 AM
Looks good, I hope that does it for you!
#8 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted December 20, 2014 - 09:22 AM
Looks good Kenny. Did you re-enforce it with anything? I've never tried plastic welding, any tips/issues?
#9 KennyP OFFLINE
  • 37,451 Thanks
  • 45,472 posts
Posted December 20, 2014 - 09:35 AM
I just melted a good amount of 'new' plastic in there, spreading it around and blending it at the edges. Since it is a gas tank, I didn't want anything foreign in there!
#10 MH81 OFFLINE
Posted December 20, 2014 - 09:39 AM
Once it passes the leak test, you could rough up the surface near the crack and bridge/reinforce/coat with some fiberglass tape and some plastic weld. Just a thought.
The repairs look nice Kenny. Hope it holds another 40 years for you.
#11 OldAllis52 OFFLINE
OldAllis52
  • 273 Thanks
  • 160 posts
Posted December 20, 2014 - 10:19 AM
Looking good! Interesting that it looks to have the smaller front wheels off a 410 on it. When you decide to sell parts off what is left let me know because I need a few things.
#12 KennyP OFFLINE
  • 37,451 Thanks
  • 45,472 posts
Posted December 20, 2014 - 01:22 PM
Finally got it to stop the pin hole leaks! Bet I filled that thing 10 times!
It's hard to part it, but I haven't a use for two of these with one mower deck. The engine will go on my Ford. I'll keep the tires & wheels and the grille as it is better than mine. After that, I am unsure of what to keep. Probably the BGB. I need to look over the other one and see what it needs or what to swap. Send me a PM for the things you want.
  • MH81 and OldAllis52 have said thanks
#13 KennyP OFFLINE
  • 37,451 Thanks
  • 45,472 posts
Posted December 20, 2014 - 03:01 PM
Well, it runs well and drives out pretty good for not having a steering wheel! Even charges! Starts real quick too! The engine sounds very healthy. It is painted a light gray color leading me to believe it is a replacement block. The Ford will be happy!
#14 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted December 20, 2014 - 05:01 PM
... Probably the BGB...
BGB?  WTF does this mean? I have seen it used over the last few days and I have no clue to its meaning.
I'm just wondering if I should check to see if mine is missing. :rolling:
#15 KennyP OFFLINE
  • 37,451 Thanks
  • 45,472 posts
Posted December 20, 2014 - 05:25 PM
BGB= Bevel Gear Box! It's in the driveline of these units! These are NLA!
  • Bmerf said thank you
