Massey 1855 to a 4855
175 replies to this topic
#91 olcowhand ONLINE
  • 42,455 Thanks
  • 31,824 posts
Posted April 14, 2011 - 10:42 AM
Oh yes, very nice! This is gonna be a super awesome 4WD!
#92 massey driver ONLINE
massey driver
  • 1,483 Thanks
  • 1,591 posts
Posted April 14, 2011 - 05:14 PM
It's looking good Ducky.It'll be nice to see it in action. Larry
#93 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted April 27, 2011 - 07:29 AM
Well we got the steering orbitol mounted and started the Hydraulic plumbing for the steering.
Here are the Left/Right hoses from the steer orbitol.
Then we used a pair of bulkhead fittings to get thur the drop case mounts.
Then hosed from them to the cylinders. Not quite done as we need a little more hose and some fittings.
I also filled the hydro filters and and the hydros them selves as we will need to fire her up the verify the oil flow to the steering before final hookup.
#94 olcowhand ONLINE
  • 42,455 Thanks
  • 31,824 posts
Posted April 27, 2011 - 07:55 AM
Boy is that red paint perty!
#95 KennyP OFFLINE
  • 40,192 Thanks
  • 46,794 posts
Posted April 27, 2011 - 08:47 AM
Lookin' real good, Ducky.
#96 mjodrey OFFLINE
Posted April 27, 2011 - 10:14 AM
That IS looking nice,great job so far Ducky.:thumbs:
#97 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted May 05, 2011 - 08:24 PM
Houston We Have A Problem
Tried to fire with hydros hooked up and only LOTS of smoke.
Engine runs on it own just fine.
Determined that the 2 - 1 overdrive is to much load for the engine to get above crank speed and run on it's own. Was told this engine is governed at 1800 rpms. Well there I go not doing my home work and actually check this out.
Removed the drive shaft and the tach said 2500. At least I will be able to lower my over drive and try to fire again.
Does anyone know these fuel pumps and if the rpms are adjustable from the outside of the pump? I would like to bring it up to 3000 to keep the over drive as low as possible and maintain 3600 - 4000 rpm input to the Hydros.
#98 massey driver ONLINE
massey driver
  • 1,483 Thanks
  • 1,591 posts
Posted May 06, 2011 - 07:06 AM
Hey Ducky sorry too hear about the problem.I know this may seem far fetched but even at idle the diesel is only running maybe 1000 rpm so even at 2-1 it still should have no problem turning the hydros.Here's one question for you are both pumps put onto the trans the same way??? The pumps are interchangeable for LH & RH rotation.Maybe you have one running one way and the other running the other way.Seems to me that the hyds are working against itself.You have the pumps facing each other and running on the same shaft ,so your going to have one running CCW rotation and one running CW rotation in order to keep them from working against each other .Larry
Edited by massey driver, May 06, 2011 - 07:23 AM.
#99 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted May 06, 2011 - 07:50 AM
Hi Larry
This motor turns the opposite direction of the Onan so I left the front pump as is and change the rotation on the rear hydro.
I am going to drop the drive sprocket down from 41 to 30 tooth and leave to driven at 20 tooth. That will give me a final of 3750 rpms with the engine @ high idle.
One interesting thing is in the OEM application this engine had a centrifugal clutch on it so it started under no load all the time. I figured that this was to aid cool weather starting. Now I am starting to wonder.
#100 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted June 19, 2011 - 05:30 PM
Last minute update before Arkansas WI. Show.
Duals on the front.
Seem to have an upload issue with Pics.
Will check and try again.
#101 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted June 19, 2011 - 05:31 PM
Here ya go!
Edited by olcowhand, June 19, 2011 - 10:08 PM.
uploaded pics for ducky
  • DANS2400 said thank you
#102 tractormike OFFLINE
tractormike
  • 172 Thanks
  • 1,488 posts
Posted June 20, 2011 - 06:04 AM
WOW Ducky that is becoming one awesome looking machine! It looks like Big Bud's little brother has been found. Can't wait to see it next saturday!
#103 mjodrey OFFLINE
Posted June 20, 2011 - 06:29 AM
That is going to look mean with those duals.:thumbs:
#104 KennyP OFFLINE
  • 40,192 Thanks
  • 46,794 posts
Posted June 20, 2011 - 06:33 AM
Looking good, Ducky. Glad you got the pics posted. You have a couple dollars in those tires, I guess.
#105 massey driver ONLINE
massey driver
  • 1,483 Thanks
  • 1,591 posts
Posted June 20, 2011 - 07:16 AM
Wow & Wow.Thats really starting too look good.It's going to be a awesome looking tractor once it's done.Can hardly wait to see it put all together.Larry
