Massey 1855 to a 4855
175 replies to this topic
#31 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted March 15, 2011 - 10:51 AM
Ducky, looking VERY nice! One question....the way it's set up, one hydro will turn CW, the other CCW. I've been told by Tudor that more has to be done other than just turning the charge pump plate....or are you simply using reverse on one hydro to match forward on the other? But this gets confusing, being one MUST run in reverse for forward motion. I figure you've already done your homework on this. My mind is foggy today anyway......raining again!!!!!
I sure love the work you've done.....quite a project to take on!
#32 NUTNDUN OFFLINE
  • 10,353 Thanks
Posted March 15, 2011 - 10:52 AM
Awesome work Ducky. Are you going to have enough up and down movement on the pivot for most terrain? Looks like it would have enough rotation and movement for most terrain, I am just wondering about going in and out of furrows at an angle maybe?
The drop box looks sweet :D
#33 Chuck_050382 OFFLINE
Chuck_050382
  • 276 Thanks
  • 1,498 posts
Posted March 15, 2011 - 10:53 AM
looks good Ducky,
What did you use for the bottom pivot point?
#34 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted March 15, 2011 - 11:00 AM
I was under the understanding that turning the front pump cover was all that was needed.
I believe turning the pump backward would cause all kinds of problems inside with oil flow and the likes.
Perhaps Tudor could chime in and set me straight.
#35 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted March 15, 2011 - 11:01 AM
I can pick any wheel 8" and have movement.
#36 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted March 15, 2011 - 11:03 AM
looks good Ducky,
We used a cat 1 hitch ball socket.
#37 Chuck_050382 OFFLINE
Chuck_050382
  • 276 Thanks
  • 1,498 posts
Posted March 15, 2011 - 11:22 AM
sounds good. I couldn't see in the pictures.
#38 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted March 15, 2011 - 01:54 PM
After reviewing the manual I believe Suntrand rotational change can be done by just changing the charge pump so it will supply the hydro charge pressure instead of sucking when the rotation is changed.
I did read in the Eaton manual that more internal changes need to be made in order to change there rotation.
Please jump in and correct me if I have this wrong. I will be firing this thing hopefully this weekend.
#39 Texas Deere and Horse OFFLINE
  • 14,889 Thanks
  • 15,514 posts
Posted March 15, 2011 - 02:12 PM
Ducky, In the picture of the drive line from engine to gear case, are you going to mount the coupling end in a bearing or are you going to let the love joy coupling carry the shaft? I have never set one up this way without a carrier bearing close to the coupling?
http://gardentractor...lation-013-jpg/
Thought I would ask. Project looks fantastic, what a build !!
#40 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted March 15, 2011 - 02:22 PM
Ha, I had the same thoughts about that to and plan to go with a u-joint for the final assembly. I think there could be balnce problem develop over time as the rubber wears.
#41 Texas Deere and Horse OFFLINE
  • 14,889 Thanks
  • 15,514 posts
Posted March 15, 2011 - 02:41 PM
Yes Sir, that will take care of that issue. If you wanted to use the coupling, all you would need is a flange mount bearing and a mounting plate. The coupling would take some of the shock out between drive line and engine.
#42 ducky OFFLINE
  • 1,989 Thanks
  • 4,108 posts
Posted March 17, 2011 - 03:18 PM
Here she is with the hood.
#43 jj69chev OFFLINE
jj69chev
  • 24 Thanks
  • 150 posts
Posted March 17, 2011 - 03:22 PM
coming along nicely, very impressive
#44 NUTNDUN OFFLINE
  • 10,353 Thanks
Posted March 17, 2011 - 03:30 PM
Looks great ducky. I am anxious to see what it looks like with the rest of the body work and the controls.
Is this your shop that you are doing all the work in?
#45 massey driver ONLINE
massey driver
  • 1,510 Thanks
  • 1,598 posts
Posted March 17, 2011 - 03:33 PM
The biggest problem with what your doing is this? Now I'am gonna want one.LOL .Looking very nice for sure.Larry
