Newbie - FOrd LGT14D
12 replies to this topic
#1 EggsBenedict OFFLINE
EggsBenedict
  • 1 Thanks
  • 1 posts
Posted December 17, 2014 - 04:28 PM
Hi all,
Just an introduction really - had a Ford LGT14D delivered today. Very pleased with it. Does seem to be a bit of a rarity, although I can see that it's basically a Shibaura GT141 in Ford clothing - not that that seems to help with info on the model.
Would be cool to know if there's a manual available for it that would show a procedure such as mower deck removal. I'd like to give it a bit of a service....
Cheers,
Eggs
  • T Guiles said thank you
#2 icecream4070 OFFLINE
icecream4070
  • 61 Thanks
  • 103 posts
Posted December 17, 2014 - 05:03 PM
Any pics
#3 KennyP ONLINE
  • 37,451 Thanks
  • 45,472 posts
Posted December 17, 2014 - 05:12 PM
From what I see in this parts breakdown, there are some spring-loaded pins to pull. Other than that, I haven't a clue!
  • TomLGT195 said thank you
#4 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted December 17, 2014 - 08:26 PM
:welcometogttalk:  Welcome to GTtalk, Eggs. Glad to have you aboard.
#5 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted December 17, 2014 - 09:17 PM
WELCOME to GTTalk!
#6 T Guiles OFFLINE
T Guiles
  • 953 Thanks
  • 749 posts
Posted December 18, 2014 - 12:11 AM
Welcome...
#7 TomLGT195 OFFLINE
TomLGT195
  • 3,697 Thanks
  • 2,761 posts
Posted December 18, 2014 - 05:28 AM
:welcometogttalk:  :wewantpics:
glad to have you here. enjoy the site. Tom
#8 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,748 Thanks
  • 4,242 posts
Posted December 18, 2014 - 06:05 AM
:welcometogttalk:
#9 JDBrian ONLINE
  • 9,606 Thanks
  • 14,142 posts
Posted December 18, 2014 - 07:12 AM
Welcome to the forum. Congratulations, that's a very nice tractor and not very common. I have seen a couple of them up here.
#10 luvin Jesus OFFLINE
luvin Jesus
  • 1 posts
Posted January 04, 2015 - 12:18 AM
Check out the manuals page of this site.  I have the same tractor and recently rebuilt the spindles and gearbox.  I found manuals covering pretty much everything on the manual site.
http://gardentractor...tors-manualpdf/
#11 SNUFFY OFFLINE
SNUFFY
  • 187 Thanks
  • 268 posts
Posted March 22, 2015 - 08:49 AM
glad to see another 14D owner on here....seems like there as many across the sea as there are ....another guy on here from Australia....I`m feeling kind of lonesome here :wave:  Post all you learn....I`ll be reading !
#12 Miner OFFLINE
Miner
  • 1 Thanks
  • 4 posts
Posted July 03, 2015 - 01:25 PM
Deck removal:
  1. On flat ground with enough room to pull the deck out from under the machine and engage park brake;
  2. Remove the height control pin from the rear idler wheels, raise the shaft and rotate to locate the bottom most hole (the wheel will be positioned 90 degrees to its normal position);
  3. Lower the deck;
  4. Pull the two spring loaded pins attaching the deck to the lift arms;
  5. Raise arms, turn off engine and remove key;
  6. Disconnect drive-shaft from tractor by sliding collar back and pulling shaft towards deck;
  7. Pull the two spring  loaded pins attaching the deck to the front arms;
  8. Pull the deck out from under the tractor, and
  9. Remove the front arms from the tractor if you intend to move/use the tractor without the deck.
Installation is in the reverse order of removal.  The same procedure applies to Ford / New-Holland Diesel lawn-tractors well into the 90's.
  • Chopperhed said thank you
#13 SNUFFY OFFLINE
SNUFFY
  • 187 Thanks
  • 268 posts
Posted July 18, 2015 - 07:18 PM
Thanks for the info Miner....I got the missing spring for my mower PTO engager idler....haven`t really had time to fool with mine due to gardening and what not....
Once I get the mowing deck running I`m going to pull it.
I`m trying to conjure me up a 3 point and cultivator to use in the garden for the rest of the season. If I can figure out where to tap into the hydraulics and a place to mount the CV...I think I can work out the rest.
