Bolens tiller model #51333 assist spring for gt 2000
tiller 51333 lift mechanism
11 replies to this topic
#1 Duratrac OFFLINE
Duratrac
  • 9 Thanks
  • 6 posts
Posted December 17, 2014 - 11:11 AM
Hi All just stumbled onto this forum..Lots of Info! Does anybody have any info on the vertical assist lift spring for this tiller? (I too an a diehard Bolens fan...had my GT2000 for nineteen years .....still mows and runs like a champ) I just bought this tiller but this spring was missing. Pic shows where it mounts. thanksIMG_20141217_102305033.jpg
  • blackjackjakexxix, Zekkjacen and logmillingman have said thanks
#2 MyBolens1053 OFFLINE
MyBolens1053
  • 689 Thanks
  • 602 posts
  • Location: Martinsburg, WV (surrounded by Apple Orchards)
Posted December 17, 2014 - 11:43 AM
Welcome to GTTalk, Duratrac. Someone with knowledge on this model will catch this soon and give you a reply to your question. I will say you came to the right place for Bolens related questions.
  • blackjackjakexxix and logmillingman have said thanks
#3 Duratrac OFFLINE
Duratrac
  • 9 Thanks
  • 6 posts
Posted December 17, 2014 - 12:03 PM
Thanks 1053 also need info on the gearcase  lube and how to check it.....the fill cap is on top......my mower deck gear oil is on the side ...fill to top of the hole...this puzzles me. I have been trying to find an owners manual but no luck so far. I did buy a parts diagram that shows this spring but only a part number.no specs. thanks again and yes seems to be a great forum!!
  • logmillingman said thank you
#4 bhts OFFLINE
bhts
  • 1493 Thanks
  • 2181 posts
Posted December 17, 2014 - 12:14 PM
I have the spring new just send me a pm or give us a call.
  • Duratrac and logmillingman have said thanks
#5 Duratrac OFFLINE
Duratrac
  • 9 Thanks
  • 6 posts
Posted December 17, 2014 - 02:21 PM
Bob thanks and I'll be calling you.....any chance you have the upper bracket (spring support) that bolts to the rear end that the spring hooks to... #59 part #1744928, the bracket that attaches to the lift arm (lift arm assembly) #65  part #1744936, lift cable #63 part#1744967 nylon pulley( white roller) #73 part #1734508?  I can probably fab the spring support and the lift arm assembly.....my cable is frayed where the previous owner had it hooked up to his tractor without the lift spring and therefore flat sided the roller trying to pick up all that weight and bolted too tight so it wouldn't turn. One other piece of info I am looking for is where the roller attaches....previous owner had it hooked to the right hand hitch arm #58 back hole (third) but told me he wasn't sure about that. Parts diagram is hard to tell....... any information is greatly appreciated!
#6 bhts OFFLINE
bhts
  • 1493 Thanks
  • 2181 posts
Posted December 17, 2014 - 02:52 PM
Let me look an see what I have new or used.
#7 Duratrac OFFLINE
Duratrac
  • 9 Thanks
  • 6 posts
Posted December 17, 2014 - 05:02 PM
Bob thanks a bunch! ....any info from anyone on the amount of gear oil this is supposed to have would be greatly appreciated...the parts manual mentions as a part number# 1700132 -- Gear Lube EP90 16 oz Tube.........soooo16oz??? thanks
#8 Zekkjacen OFFLINE
Zekkjacen
  • 211 Thanks
  • 224 posts
Posted August 12, 2018 - 12:01 AM
Bob,  do you still have these springs available?
#9 Zekkjacen OFFLINE
Zekkjacen
  • 211 Thanks
  • 224 posts
Posted August 19, 2018 - 09:57 AM
Would any of you fine gentlemen out there be able to give a length and or description of the assist spring described here?
#10 blackjackjakexxix OFFLINE
blackjackjakexxix
    Blackjackjakexxix
  • 3726 Thanks
  • 2367 posts
Posted August 19, 2018 - 08:09 PM
Also looking for the part number of the spring
#11 29 Chev OFFLINE
29 Chev
    A Little Off Plumb
  • 22761 Thanks
  • 7524 posts
Posted August 20, 2018 - 06:43 AM
Wonder if it is the same spring that was used on the 50333 model tiller - item # 55 - part number 1714844?
https://www.partstre...neral-assembly/
  • Zekkjacen and logmillingman have said thanks
#12 Zekkjacen OFFLINE
Zekkjacen
  • 211 Thanks
  • 224 posts
Posted August 23, 2018 - 12:17 PM
I would think so. I missed that in my search!
