tire chains on concrete
7 replies to this topic
#1 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted December 14, 2014 - 12:20 PM
How much will the chains scratch up my concrete drive..I want to put the chains on BUT don't want to find out the chains scuffed up my good concrete.  And I don't want to put them on in the middle of winter if I need them and it's COLD...  It's going on a 1556 bolens,, with 40# weights and my 200 LB fat a$$... Any thoughts.???
        Thanks  sodi
  • hamman, T Guiles and FrozenInTime have said thanks
#2 Bolens 1000 ONLINE
  • 14,986 Thanks
  • 18,140 posts
Posted December 14, 2014 - 12:24 PM
All depends on how much spinning you do as to the severity of the scuffing.
They will definitely make small scratches no matter what though
If you want I sell rubber tire chains which work just as good as steel chains in the snow IMO, been using a set on my 1050 for about 4 years now.
  • sodisr, superaben, T Guiles and 1 other said thanks
#3 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted December 14, 2014 - 12:47 PM
I've used those rubber strap chains.  They do a good job.
Ben W.
  • Bolens 1000, sodisr, T Guiles and 1 other said thanks
#4 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted December 14, 2014 - 01:58 PM
Chains can be very harsh on nice concrete. If you do not use chains ice will be your worst enemy. My concrete and blacktop have a lot of scratches from the past several years. The advantage is the availability of pushing large quantities of snow.
Geno
  • sodisr, FrozenInTime and propane1 have said thanks
#5 PGHsteelworker OFFLINE
PGHsteelworker
  • 96 Thanks
  • 55 posts
Posted December 14, 2014 - 06:19 PM
Any chain you use on concrete is going to mark it up if you do any spinning at all. Try those rubber straps or use chains with a lot of weight to minimize spinning.
  • sodisr said thank you
#6 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted December 15, 2014 - 11:56 AM
Those rubber ones work well.???   That's fantastic,,didn't know they existed..I don't push snow,, I use a 38" snocaster on my 1556 bolens.. So no great pushing required..  Last year no weights,, no chains,, probably icy  and It was useless...  I had to use the 2-cycle snow pup..
   Doc.. could you P M me on those rubber chains...          Thanks   sodi
#7 Bolens 1000 ONLINE
  • 14,986 Thanks
  • 18,140 posts
Posted December 15, 2014 - 01:25 PM
Sure, will shoot you a PM with details, I actually just ordered another set for my EK10 with snow caster because I was scuffing my drive with the metal chains since the EK's don't have as much traction as the regular Garden tractors.
#8 PGHsteelworker OFFLINE
PGHsteelworker
  • 96 Thanks
  • 55 posts
Posted December 15, 2014 - 02:48 PM
I have a very and long driveway and plow a multi family driveway as well because they have no tractor. I have used ags with standard and heavy duty chains with some success. Bought a set of 2 link v-bar chains last year and put them on a set of turf tires I recently picked up and that set up is THE best combo for winter snow / ice traction on gravel / dirt surfaces I have ever used. Those v-bar chains will definitely mark up any concrete /cement / or brick surfaces. Old set upDSCN0567copy.jpg New set upIMG_20140924_114806567_HDRcopy.jpg IMG_20141003_150808612_HDRcopy.jpg
