Wanted
Small 3-4 speed transmission assembly
economy power king
5 replies to this topic
#1 farmtoybuilder OFFLINE
farmtoybuilder
  • 13 Thanks
  • 27 posts
Posted December 14, 2014 - 11:12 AM
 Have a friend needing a small compact Transmission assembly for a project. I was thinking an old Power King or Economy transmission? What others used a sperate transmission? perfer cast iron case. Open to suggestions! Need one ASAP.
Thanks
email us at farmtoys@sbcglobal.net
#2 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted December 14, 2014 - 12:48 PM
Are you wanting one with a shaft drive input or belt drive?
Ben W.
#3 glgrumpy ONLINE
  • 8,561 Thanks
  • 7,881 posts
Posted December 14, 2014 - 02:00 PM
You would need a clutch and bellhouse too to put on most engines. OR, Speedex used same trans sideways in chassis with belt pulley on drive end and sprocket on other, BUT, the case was beefed up with dual bearings on the input end and a diff main shaft for those. You will have to realize these trannies are NOT cheap to buy. Epay has them on lots of times, several hundred dollars for most offers.
#4 farmtoybuilder OFFLINE
farmtoybuilder
  • 13 Thanks
  • 27 posts
Posted December 14, 2014 - 04:17 PM
Thanks for replies! would prefer imput with Drive shaft. We have been looking on ebay and haven't seen any.
#5 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted December 14, 2014 - 04:48 PM
Thanks
I have a 3 speed trans from a Power King, and I believe, a bell housing with the clutch release lever.  I'd want $225 for the tranny, and $50 for the bellhousing--that's what I have into them. I may have a clutch plate, etc. but would have to check.
Regards,
Utah Smitty
  • farmtoybuilder said thank you
#6 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted January 01, 2015 - 03:26 AM
I just thought of something else I have that you might be interested in-- a manual transaxle out of a Cub Cadet narrow frame tractor.  It is a three speed, and includes the axles, differential, tranny, and input shaft that connects to the shaft from the engine.
I'd sell it for $150 + freight.
Let me know if that would work for your application.
Smitty
Also tagged with one or more of these keywords: wanted, economy, power king
