First bush hog (photos)
21 replies to this topic
#16 Titus OFFLINE
    Bush Hog Hoarder
  • 1,843 Thanks
  • 2,334 posts
Posted December 15, 2014 - 05:38 PM
I posted the S# on the 12th here
Scott will be in touch I'm sure with it's year. Our manual section will have every manual you'll need for this machine.
Have fun!
#17 sacsr OFFLINE
    Bush Hog Addict
  • 3,468 Thanks
  • 3,369 posts
Posted December 15, 2014 - 07:38 PM
The serial number plate is there
#8054, if anyone could help with a year.
I am trying to find a pdf of the owners manual also.
The motor date is 1966. The first time the D4-10 shows up in a price list, that I have, is October of 1966. I suspect it was in the second half of 1966 when it was built. Just a guess....but I have a tractor with serial number 8386 that was sold in March of 67, to use as another point of reference.
  • olcowhand and dlang94 have said thanks
#18 dlang94 OFFLINE
  • 245 Thanks
  • 169 posts
Posted December 18, 2014 - 01:39 PM
The engine gave me some problems, I changed the oil and added some sea-foam to it and added some sea-foam to the gas (new gas) was running fine then shut off and was locked up. Pulled the motor off and opened it, nothing seems broken and it moves free now. I plan to dissemble the engine and clean the inside parts as well as see if something needs replacing. I have never dissembled or rebuilt an engine before but found a manual online for the tr10d engine that tells how to rebuild it. I wont get to disassembling until tomorrow night or Saturday. The piston ring doesn't look right from what I could see. My concern is parts if something does need to be replaced. Any advice?
Edited by dlang94, December 18, 2014 - 01:51 PM.
  • Bolens 1000 and Texas Deere and Horse have said thanks
#19 Texas Deere and Horse OFFLINE
  • 14,859 Thanks
  • 15,510 posts
Posted December 18, 2014 - 01:46 PM
Here is the manuals we have on GTtalk, I hope they will help you out.
Service manual on TR and TRA-10
Parts Manual on TR and TRA
This may also be a parts manual, not really sure as I didn't down load it to see.
  • dlang94 said thank you
#20 KennyP OFFLINE
  • 39,027 Thanks
  • 46,259 posts
Posted December 18, 2014 - 01:51 PM
I wouldn't put Seafoam in the oil. Use MMO (Marvel Mystery Oil) for that and not much! Thins it too much!
#21 Bolens 1000 OFFLINE
  • 15,119 Thanks
  • 18,182 posts
Posted December 18, 2014 - 04:45 PM
If you have any engine questions along the way we are here for you.
As for parts availability most are still available, let me know what you need I am a Wisconsin dealer.
If you have never taken an engine apart though I would suggest that any work that needs to be done such as honing , piston ring replacement ect  should be done by a small engine guy, or if you want to learn start practicing  on an engine thats cheap work on if something breaks
  • Texas Deere and Horse and dlang94 have said thanks
#22 olcowhand OFFLINE
  • 41,817 Thanks
  • 31,614 posts
Posted December 18, 2014 - 05:48 PM
Can you post some pics of the engine internals such as cylinder bore, piston/rings, crank rod journal, and the rod big end?
