UEG 1500 D
4 replies to this topic
#1 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted December 13, 2014 - 06:42 PM
A call came in a few days ago for a solution to providing electricity during power outages.
My custom built semi-portable diesel genset UEG 1500 D is to be remanded to the Westhampton property, in discourse the electrical enclosure is to be replaced, below is the start.
Disassembly of the original electrical enclosure.
Measuring and mounting new electrical enclosure.
Drilling the mounting holes and genhead output wires.
Drilling rectifier and capacitor holes.
Drilling the engine function switch and genhead master switch.
Drilling and filing out holes for duplex reciprocal.
Drilling the mounting holes for the reciprocal and weather cover.
Fact finding test assembly for problems and needed modifications.
This will be my last project for 2014 and very well for a long time.
More to come.
  • KennyP, Cvans, New.Canadian.DB.Owner and 3 others have said thanks
#2 KC9KAS OFFLINE
KC9KAS
  • 5,468 Thanks
  • 4,723 posts
Posted December 13, 2014 - 07:21 PM
post-5127-0-05556500-1418513252_thumb.jp  How fast you have to crank to get 120 VAC @ 60 Hz? :poke:  :bigrofl:
Nice looking generator!
Edited by KC9KAS, December 13, 2014 - 07:22 PM.
#3 petrj6 OFFLINE
petrj6
  • 4,084 Thanks
  • 2,369 posts
Posted December 13, 2014 - 09:17 PM
   Ok I gotta ask, is that an old set of air comp tanks under their being used for fuel tanks?  I like it !!  How much power will that put out ? must run forever with that sort of setup. got to go maybe 24 hours on a tank?
        Pete
  • trowel said thank you
#4 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted December 14, 2014 - 08:10 AM
        Pete
Pete,
Modified/converted spare Lindsay 25 air compressor tanks into dual tube type fuel tanks with built in skids and duel filler caps with inline tank selector switch, 4 gallons per tank making for a total of 8 gallons, taking into account head space per tank, 7 1/2 gallons, 4 1/2 days continuous at continuous 3/4 load, 6 1/2 days on the variable switch (systematic cycling on/off load) . Remained from it's semi-prime duties semi-permanently attached to the house via secondary power lines for powering the emergency electric heat, cooking and connected to intergraded automatic variable on/off load switch charging deep cycle battery bank for lights and sensitive electronics (computers) at the Williamsburg property during outages accommodated by the manual start military built gas powered Prime Mover hence the electrical enclosure conversion to utilitarian type.
Specs below :
UEG 1500 D Skid Mounted, Semi-portable : ( Utility Electric Generator - 1,500 Watts conservatively, Diesel, Skid Mounted )
- 2003 Lister Petter  Alpha model AC1 series 3 with modified head and injector for continuous long run at 1,800 rpm.
- Direct-coupled heavy duty modified (high output circulation fan) Copper-wound 4-pole Markon series 4, single (switchable) Capacitor excited, dual rectified ( one per pole ) replaceable carbon brush type alternator with no AVR, transisters, volt regulator or coil of any kind.
-  Muffler mounted above head to aid in continuous sub-temp operation keeping head temp continuous during low volt operation (charging/stand-by mode).
- Electric cold start aid air intake heater element.
- De-ice warm air intake for sub-temp running.
- Mechanical fuel lift pump.
- Heavy duty paper element fuel filter.
- Electric start.
- Head decompression valve lever for manual starting.
- Raised manual hand crank starter.
- Valve-lash adjusted for 1,800 rpm deep intake/exhaust and modified head.
Edited by trowel, December 14, 2014 - 04:49 PM.
#5 trowel OFFLINE
trowel
    Summer.
  • 4,844 Thanks
  • 4,535 posts
Posted December 14, 2014 - 04:54 PM
Finishing up today.
Run/stop lever added.
Decompression lever added, cable held in place with modified throttle cable bracket.
Load testing : http://youtu.be/yByPQqI57tE
Ready for service.
