Deere 37 snow thrower thrown belt
11 replies to this topic
#1 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted December 13, 2014 - 12:13 PM
I have a model 37 snow thrower on my 210 with electric clutch I put a twist in the belt so the auger will go the right direction and now the belt jumps from the idler pulley to the v pulley on the thrower what would cause this thank you
#2 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted January 31, 2015 - 09:17 AM
Any help would be greatly appreciated
#3 Trav1s ONLINE
Trav1s
  • 3,307 Thanks
  • 4,362 posts
Posted January 31, 2015 - 09:59 AM
Is it a 37 or a 37a?  Got a serial number?
#4 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted January 31, 2015 - 10:09 AM
Model e0680 serial 107291m
#5 grnspot110 ONLINE
grnspot110
  • 4,151 Thanks
  • 2,644 posts
Posted January 31, 2015 - 10:14 AM
I had the same problem with a 37, so I found a 37A, no more problem!
#6 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted January 31, 2015 - 10:31 AM
What brand belt are you using?
#7 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted January 31, 2015 - 10:49 AM
I can't rememer now I got it from tractor supply it's a bluish color
#8 grnspot110 ONLINE
grnspot110
  • 4,151 Thanks
  • 2,644 posts
Posted January 31, 2015 - 11:02 AM
Best to use only John Deere belts on JD equipment!  They have a slightly different bevel.
  • ace69xxx2000 and Trav1s have said thanks
#9 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted January 31, 2015 - 11:04 AM
Ok thank you I will try to get one Monday from the dealer
#10 Trav1s ONLINE
Trav1s
  • 3,307 Thanks
  • 4,362 posts
Posted January 31, 2015 - 12:01 PM
The part number on the belt is M45998
Got it from www.jdparts.com
Edited by Trav1s, February 01, 2015 - 06:56 AM.
  • ace69xxx2000 said thank you
#11 lyall OFFLINE
lyall
  • 2,072 Thanks
  • 1,545 posts
Posted February 01, 2015 - 12:39 PM
check and see if the pulleys are aligned
check the pivot bolt #7 and the bushing #8 to see if it is worn
if they are worn you can not align the belt
mine were worn and eat the belt up
Edited by lyall, February 01, 2015 - 12:40 PM.
#12 ace69xxx2000 OFFLINE
ace69xxx2000
  • 22 Thanks
  • 130 posts
Posted February 02, 2015 - 08:10 PM
Ok I will take a look at that thank yoi
