Steering Wheel Hub
9 replies to this topic
#1 Traill95 ONLINE
Traill95
    Traill95
  • 1,828 Thanks
  • 1,003 posts
Posted December 12, 2014 - 02:07 PM
During the restoration of my Ge Elec-Trak I needed to replace the steering wheel. I use to build Street Rods and have always had a liking for the Grant Steering Wheel.DSC01775.JPG
So with a piece of pipe, a Large Washer (very large) and a piece of solid pvc I made a hub to mount the Wheel onto the Elec-trak. Now all I need is to come up with a cover between the wheel and the dash.
To anyone thinking about getting a Lathe and or a Mill, they are worth having. Ours have paid for themselves several times.
Edited by Traill95, December 12, 2014 - 02:24 PM.
  • olcowhand, DH1, Lmiller3358 and 7 others have said thanks
#2 Lmiller3358 OFFLINE
Lmiller3358
  • 1,466 Thanks
  • 1,412 posts
Posted December 12, 2014 - 02:47 PM
Good job !
  • Traill95 said thank you
#3 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 12,634 Thanks
  • 9,446 posts
Posted December 12, 2014 - 02:50 PM
When I was a kid, they used to sell those steering wheels real cheap at Kmart. They're not so cheap anymore.
#4 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted December 12, 2014 - 03:04 PM
Great work. :thumbs:
.... Now all I need is to come up with a cover between the wheel and the dash.
Don't know the size of the shaft, but how about a simple piece of heater hose? Cut to length, with some RTV or silicone at the top to seal and hold it up off of the dash. Or if bigger, maybe a universal flex hose for the accordion look.
Edited by Bmerf, December 12, 2014 - 03:06 PM.
#5 Traill95 ONLINE
Traill95
    Traill95
  • 1,828 Thanks
  • 1,003 posts
Posted December 12, 2014 - 03:59 PM
Going to need something accordion like because I have to push it down to install the spring pin that will hold the wheel hub in place.
#6 Sawdust ONLINE
Sawdust
  • 5,463 Thanks
  • 3,296 posts
Posted December 12, 2014 - 07:30 PM
Not sure on the diameter you need but will a 1 1/4" flexible pvc drain pipe painted black work.
#7 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted December 12, 2014 - 08:22 PM
I don't know how this would work, but it is a suggestion:
Black shock boot:
http://www.summitrac...CFQwPaQodJo4Aqw
or yellow (might have to look at different manufactures to find appropriate color):
http://www.summitrac...CFY87MgodCEkAWA
or
http://www.roughcoun...boot-87148.html
A couple of washers doubled up on the ends would help to hold the correct shape.
Edited by Bmerf, December 12, 2014 - 08:24 PM.
  • Traill95 and superaben have said thanks
#8 Traill95 ONLINE
Traill95
    Traill95
  • 1,828 Thanks
  • 1,003 posts
Posted December 12, 2014 - 09:43 PM
I was thinking about using just that. seen it on the back of the washer tonite and realized that that would be just about right.
  • Sawdust said thank you
#9 Traill95 ONLINE
Traill95
    Traill95
  • 1,828 Thanks
  • 1,003 posts
Posted December 12, 2014 - 09:48 PM
Black shock boot:
or
I wonder what the diameter is on the shock boot. I would want a black one. I would need an inside diameter of between 1 and 1 1/4 inch. with the outside diameter not more than 2 inches, 2 1/4 at most.
#10 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted December 19, 2014 - 10:48 PM
Had a brain storm or fart depending on how you want to look at it.
Yesterday while at the scrap yard I noticed that the wiring harness cover that runs between the door and the body of the vehicle is a nice soft rubber accordion tube. I was acquiring parts off of a mid '90s Ford truck, but I am sure others would work. It was about 1" in diameter, ~6" long, would stretch to maybe +8", and compress to ~4". It had a big grommet on each end that could be cut off and leave a nice +1/4" flat before the accordion area. A hose clamp or zip tie could be used to secure. This might be just what you are looking for. Just another possibility. I love finding things to repurpose.
Edited by Bmerf, December 19, 2014 - 10:49 PM.
