What makes Ariens so good/expensive?
13 replies to this topic
#1 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted December 12, 2014 - 08:27 AM
More of a question out of curiosity but every time I see an Ariens for sale it's priced at least 200% higher than similarly sized well known brands. Was there something special about these tractors? Significantly better durability?
It also looks like new Ariens models have Briggs & Stratton engines. So far I can't find much of a difference between other good GTs at lower pricepoints
  • HANKG said thank you
#2 HANKG ONLINE
HANKG
  • 6,203 Thanks
  • 3,382 posts
Posted December 12, 2014 - 09:48 AM
Maybe its the inherently great German engineering Case tractor's also come with a higher price tag.
#3 aevansgatech OFFLINE
aevansgatech
  • 213 Thanks
  • 261 posts
Posted December 12, 2014 - 11:11 AM
Were the old models sold in the US? Perhaps its a low volume thing too?
#4 KohlerJunkie OFFLINE
KohlerJunkie
  • 8 Thanks
  • 18 posts
Posted December 12, 2014 - 11:36 AM
If you're talking about the older GT models, They were Built very, very well.
A little bit hard to work on, but not too bad. Plus they're very heavy so traction isn't really a problem. My 17 right now, probly weights near 1000 pounds.
My GT 17 also has front PTO also Front lift arms mid PTO rear pto 3 pt hitch, steering brakes, (some have power steering.)
Maybe they are just more rare were you live, beacause by me they're getting so cheap.  Right Now there is a GT 18 Power steering Front, Mid and rear Pto With a 60? inch deck and a 2 stage snowblower for $600.
  • JDBrian said thank you
#5 JDBrian OFFLINE
  • 9,613 Thanks
  • 14,144 posts
Posted December 12, 2014 - 11:47 AM
They are a nice tractor if you can find one that hasn't been abused and neglected. They are a bit pricier than most but not as high as CC or JD in this market.
  • sideswiper said thank you
#6 KohlerJunkie OFFLINE
KohlerJunkie
  • 8 Thanks
  • 18 posts
Posted December 12, 2014 - 12:34 PM
Agreed. Heck I can't Find a JD 110 for under $600 around me!
Edited by KohlerJunkie, December 12, 2014 - 12:41 PM.
#7 HANKG ONLINE
HANKG
  • 6,203 Thanks
  • 3,382 posts
Posted December 12, 2014 - 07:22 PM
I did not mean to infer they were made in Germany, just that the company was started by Henry Ariens
#8 shorty ONLINE
shorty
  • 5,291 Thanks
  • 5,171 posts
Posted December 12, 2014 - 08:35 PM
 I guess you are thinking of the S and GT series, the big boys of Ariens.
I think there are various reasons, heavier built, fairly well engineered, and not mass produced like the bigger manufacturers. Ariens bought the S series line from Sperry New Holland back in the 70's.
#9 dodge trucker ONLINE
dodge trucker
  • 2,313 Thanks
  • 3,025 posts
Posted December 12, 2014 - 08:53 PM
and look at brands like MTD, Simplicity, Allis  Ford/Jacobsen, and such;  they all had another brand that while painted different and had different stickers but otherwise were the same as  a tractor sold under some other name  while  Ariens is just Ariens.   You cant take a structural part like a frame or a hood or a front axle or a deck from anything "but" another Ariens, and have it fit/work properly.  I am not sayin that something can't be "made" to work  but nothing else is a direct swap. Engines transaxles etc, yeah. there is some interchange there, as these are parts that were not made "by" Ariens  but were outsourced. and also outsourced by the others,
#10 dodge trucker ONLINE
dodge trucker
  • 2,313 Thanks
  • 3,025 posts
Posted December 14, 2014 - 10:45 PM
I am on my 2nd Ariens S/GT series tractor;
  this is the 1st that will run and actually be used. my 1st one just sorta passed thru here untouched by me because it was so much more a basket case  than this one I now have was when I got it.  I was not working at the time (I was on Disability because of the chain saw kickback I experienced) had no extra parts for it or the engine which was in boxes,  No $$ to begin to think about trying to piece it back together.... so I passed it on not knowing that ~5 years later I'd have this one. If not the tractor itself I'd like to have the tiller attachment that I passed along with that 1st tractor, back....
Now just those tillers themselves, bring more money than the tractor tiller deck and snow blade brought me back then, combined!
#11 sideswiper OFFLINE
sideswiper
  • 19 Thanks
  • 15 posts
Posted December 15, 2014 - 09:06 AM
I have Three  S16H's Two of them are running & the third just needs a new carb & Coil then it will be working again the drive shaft broke right at the Transmission & it broke the Gear inside the Charge pump i was able to get a used housing & the Two gears for $50 on ebay they wanted close to $300 for just the Two gears on the internet. I have Two snow blowers, Snow Blade, Tiller, Three decks,& rear Blade for Grading my Driveway. I also have a Hard Cab for One Tractor & a Hard Top Soft Sided Cab for another. These are great little tractors & mine are worked Year round
#12 suieswam OFFLINE
suieswam
  • 26 Thanks
  • 20 posts
Posted December 15, 2014 - 10:11 AM
the old New Hollands were designed in New Holland, Pa. and built in Belleville Pa.  till they were sold to Ariens in the early 70's they just changed the paint!  I helped to build the prototypes  was a great tractor
  • sideswiper, shorty, dodge trucker and 1 other said thanks
#13 toomanytoys84 OFFLINE
toomanytoys84
    Aaron
  • 9,654 Thanks
  • 5,851 posts
Posted January 03, 2015 - 11:21 PM
I sold mine for 600 or 700 bucks. Gt17. It was a nice tractor. I used it to cut a bit then got tired of it.
They are quirky in my experience
#14 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,605 Thanks
  • 1,306 posts
Posted January 03, 2015 - 11:34 PM
Ariens are a great GT in my book and if you pull the body off the look a lot like a JD140 or early 300 series. Big block Kohler shaft driven to a hydro pump and a Dana 20 rear axle.
