Just got a Cub Cadet 106 Need help
cub cadet starter generator regulator
6 replies to this topic
#1 Cadet106 OFFLINE
Cadet106
  • 11 posts
Posted December 11, 2014 - 06:06 PM
I just got a 106, and the guy I got it from said it wasn't charging the battery. Just wondering how to test the starter generator and the regulator to see which is bad. Thanks
#2 NUTNDUN OFFLINE
  • 10,350 Thanks
Posted December 11, 2014 - 06:09 PM
Here is a link to an article that was done a while ago on Testing a Starter Generator.
  • lrhredjb, superaben and Cadet106 have said thanks
#3 Cadet106 OFFLINE
Cadet106
  • 11 posts
Posted December 11, 2014 - 06:15 PM
Ok thanks. I have to get a new battery then I can try that. Thanks
#4 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted December 11, 2014 - 07:07 PM
First of all make sure it will not charge. With engine running check for 14 volts at the battery
  • Cadet106 said thank you
#5 Cadet106 OFFLINE
Cadet106
  • 11 posts
Posted December 12, 2014 - 01:33 PM
Is there any way to test the regulator?
#6 KennyP ONLINE
  • 40,177 Thanks
  • 46,786 posts
Posted December 12, 2014 - 04:48 PM
Maybe this will help! Or maybe this?
#7 Cadet106 OFFLINE
Cadet106
  • 11 posts
Posted December 14, 2014 - 09:25 PM
Well I finally got a chance to look at it. And the wiring is all corroded and some of the ones going to the regulator were snapped in two. Guess I need a new harness.
Also tagged with one or more of these keywords: cub cadet, starter, generator, regulator
