Flywheel swap
420 p220g b43g flywheel swap
5 replies to this topic
#1 ride65 OFFLINE
ride65
  • 5 Thanks
  • 7 posts
Posted December 09, 2014 - 06:20 PM
 Has anyone out there put a B43 flywheel on a P220? I'm considering doing this to save a few bucks on a 420 I picked up that is minus the engine and driveshaft. I have a P220G out of a miller welder that I'm going through because it was smoking a tad and was going to install it in the 420. I have a B43 flywheel and a driveshaft from a 420 that had a B43 motor in it. What, If any difficulties am I looking at and is this possible? I've checked out the part numbers and they are different, But haven't checked into it in any depth beyound that.
#2 KennyP OFFLINE
  • 38,385 Thanks
  • 45,933 posts
Posted December 09, 2014 - 06:34 PM
I'm not sure if the P220 uses the flywheel to trigger the firing or not. You don't have a P220 flywheel?
#3 ride65 OFFLINE
ride65
  • 5 Thanks
  • 7 posts
Posted December 09, 2014 - 07:43 PM
I do, but I don't have the 220 driveshaft. I have the shaft for the B43. (different length) The 220 uses the electronic ignition and the 43 uses points.
#4 jms180 OFFLINE
jms180
  • 1,517 Thanks
  • 1,567 posts
Posted December 09, 2014 - 08:02 PM
The Miller welder has a different crankshaft with a taper on the end. Will that be a problem for you?
#5 ride65 OFFLINE
ride65
  • 5 Thanks
  • 7 posts
Posted December 09, 2014 - 09:16 PM
I'm goning to find out pretty soon., I do have a P218 parts motor out of a 318  that I can scavange from.
#6 KennyP OFFLINE
  • 38,385 Thanks
  • 45,933 posts
Posted December 10, 2014 - 07:40 AM
According to this manual, there were 2 different flywheels used on the P216/218/220 engines.
Also tagged with one or more of these keywords: 420, p220g, b43g, flywheel swap
