GT5000 PTO Not Working
  • This topic is locked This topic is locked
7 replies to this topic
#1 backman56 OFFLINE
backman56
  • 2 posts
Posted December 07, 2014 - 08:43 PM
Need some help,unhooked safety switches on my g t 5000,now when I engage my blades engine shuts off.
  how can I  bypass this?  model-917276022  thank you  Rick  ncpa
#2 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted December 07, 2014 - 08:58 PM
Rick, welcome to the forum!
Why do you want the safety switches unhooked? It is a lot more trouble to try to engineer a bypass than hook things up standard and operate the tractor like it was designed.  You also risk blowing electrical components when you hook up wires and connections that shouldn't be.  Something like your Craftsman has enough electrical modules to cause me concern doing too much rewiring.
Ben W.
  • NUTNDUN said thank you
#3 NUTNDUN ONLINE
  • 10,339 Thanks
Are you sure you want to bypass the safety switches? No member here will condone bypassing any safety switches. If you bypassed or unhooked the pressure switch on the seat more than likely that is what is causing it to shut off when engaging the PTO.
#4 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted December 07, 2014 - 09:24 PM
Sounds like the seat switch to me. Hook it back up and see if it fixes the problem. Or does your mower do a good job on the yard without someone steering?
#5 backman56 OFFLINE
backman56
  • 2 posts
Posted December 07, 2014 - 09:33 PM
I unhooked my safety switches on my gt 5000,now my pto shuts engine off,whats wrong  Rick
#6 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted December 07, 2014 - 09:47 PM
Your next line was going to be, "If so, I want one!"
Ben W.
#7 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted December 07, 2014 - 09:59 PM
Hook the safety switches back up. You won't get much help when it comes to dis connecting safety switches.
#8 MH81 OFFLINE
Posted December 07, 2014 - 10:34 PM
While I :welcome: you to GTtalk, we do not generally allow discussions on how to defeat manufacturers safety switches.
This position is partly because of liability, but primarily to promote the safety of our members.
Because of this, I combined the two open threads you had on the topic and will now lock the thread to avoid any negative situations or outcomes.
If you are needing information to troubleshoot the switches that are there in an attempt to put them back into working order, you may find the membership more inclined to try to assist.
  • Auburn David said thank you
