Cub Cadet 301 48" Mower Deck Restoration
mower deck cub cadet cub 2206
76 replies to this topic
#61 mike912e OFFLINE
mike912e
  • 427 Thanks
  • 241 posts
Posted March 26, 2015 - 01:50 PM
All parts installed except for the chute deflector . I also have the three blades and the graphite coating to apply underneath . I have four ball-lock pins at the wheel adjustment holes and plan on tethering them in place with braided steel fishing line . Close ! Real close . Thanks to everyone for the encouragement and suggestions along the way .
  • LPBolens, KennyP, Gabriel and 1 other said thanks
#62 KennyP ONLINE
  • 41,443 Thanks
  • 47,378 posts
Posted March 26, 2015 - 06:42 PM
Great job on that deck! Thanks for taking us along!
  • mike912e and Gabriel have said thanks
#63 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,635 Thanks
  • 4,637 posts
Posted March 26, 2015 - 06:49 PM
:thumbs:  Great Job :dancingbanana:
#64 Gabriel OFFLINE
Gabriel
  • 1,449 Thanks
  • 1,863 posts
Posted March 26, 2015 - 10:05 PM
Very nice job! Thanks for sharing your deck restoration with us! You'll probably be putting that deck to work pretty soon.
  • mike912e said thank you
#65 mike912e OFFLINE
mike912e
  • 427 Thanks
  • 241 posts
Posted March 27, 2015 - 07:01 PM
The two remaining parts are at the powder coater and I'll be picking them up either Monday or Tuesday . It's a 40 mile round trip ! Then sharpen the mower blades and install them . Then to roll the deck over bottom side up to add the graphite coating to the bottom surfaces . I hope this makes cleaning the grass residue off of the deck easier . We'll see ! Thanks for following along . Still a little way to go yet . Bear with me just a little longer .
  • KennyP and Gabriel have said thanks
#66 shorty ONLINE
shorty
  • 5,914 Thanks
  • 5,450 posts
Posted March 28, 2015 - 05:31 AM
It looks like new again. :thumbs:  Won't you be scared to use it? Being it could get a scratch.... :smilewink:
#67 mike912e OFFLINE
mike912e
  • 427 Thanks
  • 241 posts
Posted March 28, 2015 - 06:15 AM
Thanks for the compliment , but all my equipment gets used . That's also the beauty of powder coat ; it's a lot tougher than paint . Besides that it was getting quiet rusty and I needed to address that issue anyway . I'll be posting pictures of the remaining work as it progresses .
  • shorty and Gabriel have said thanks
#68 mike912e OFFLINE
mike912e
  • 427 Thanks
  • 241 posts
Posted April 03, 2015 - 09:32 AM
Just about done ! Bottom side of deck has been sprayed with the graphite coating . After it dried I rubbed it with my finger and it appears to be quiet slick . We'll give it a try this Spring/Sunmmer and see how it holds up .
Notice the 5 gallon gas can in the background . I plan on making a mount for the front of one of the narrow frames to hold the full can . Nothing worse than running out of gas !
I plan on leaving this thread open and posting Summer end pictures of the deck, especially the bottom side .
Now it's time to start tilling the gardens as soon as the dirt dries out somewhat .
I took a picture of the 2206 with the tiller and snow thrower mounted, as I'm not sure what the weather's going to do from one day to the next !
  • ENafziger and Gabriel have said thanks
#69 KennyP ONLINE
  • 41,443 Thanks
  • 47,378 posts
Posted April 03, 2015 - 06:24 PM
I'd say you have things covered no matter what happens!
#70 mike912e OFFLINE
mike912e
  • 427 Thanks
  • 241 posts
Posted May 09, 2015 - 09:56 AM
Update :
I've been using the restored deck for a couple of weeks so far and it appears to be doing a great job . My only concern is that there is quite a bit of grass adhering to the exit opening, so I have to assume that it's sticking to the bottom of the deck as well . I'll continue cutting grass for a few more weeks, pull the deck and see what's happening .
I must have it adjusted properly as the grass looks great after being mowed . Nice and smooth with no uneven areas . I went over all the grease fittings, giving them a quick shot of grease before using it the first time . Runs quiet, which is good, as it was somewhat noisy when operating before the restoration . I'll continue to keep everyone informed as time progresses .
Mike
  • KennyP and ENafziger have said thanks
#71 KennyP ONLINE
  • 41,443 Thanks
  • 47,378 posts
Posted May 09, 2015 - 09:58 AM
Glad it is working well for you.
#72 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,635 Thanks
  • 4,637 posts
Posted May 09, 2015 - 10:32 AM
Sounds like it is working fine. I have to clean under mine after each mowing with a metal 6n1 putty knife, sometimes twice, once after the front 1-1/2 acres, then after the back 1-1/2 acre. I usually can fill a 5 gallon bucket with each cleaning.
#73 FixItCharlie OFFLINE
FixItCharlie
  • 581 Thanks
  • 366 posts
Posted May 09, 2015 - 12:21 PM
Very well done project one thing I noticed is the color of the gas can. Yellow is in many places used to designate for diesel or other fuels. Some gas stations I have use will not let you fill a can with gas unless it is red in color. I know some of them have said something about liability problems.
Charlie
#74 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,635 Thanks
  • 4,637 posts
Posted May 09, 2015 - 05:48 PM
Today's Mowing, Cleaned under the deck twice, and top once. Then pressure washed. It was a wet mow, but enjoyable. Got sideways in the front ditch, still 2" of water in there, then some mudding through a stream out back. All is cleaned up now.
#75 mike912e OFFLINE
mike912e
  • 427 Thanks
  • 241 posts
Posted May 17, 2015 - 02:39 PM
Charlie
Charlie,
I'll be painting a big red and black "I" and " H " on both sides and will indicate that it's for gas only ( even though I'll be the only one using it ) .
Mike
