Testing And Repairing A Brass Float
13 replies to this topic
#1 MH81 OFFLINE
  • 29,978 Thanks
Posted December 07, 2014 - 02:03 AM
A while back, I verbally described my method of testing floats for leaks. There were some questions, so tonight I had a chance to work on one.
Testing and potential repair. Won't know until I can get a couple of minutes to reassemble the carb.
  • olcowhand, DH1, daytime dave and 11 others have said thanks
  • 14,889 Thanks
  • 15,514 posts
Posted December 07, 2014 - 02:11 AM
Very nice job Alan, looks like for have it fixed and show how to fix a good float. Thanks for the video. :thumbs:
#3 KennyP ONLINE
  • 40,901 Thanks
  • 47,101 posts
Posted December 07, 2014 - 05:49 AM
Great job on the fix, Alan! The video will be a good tool for folks! This going in the Tech Wiki?
#4 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted December 07, 2014 - 07:48 AM
Well done Alan! It's the changing temperature of the brass that heats the air and causes the pressure to increase in the float. If you were to heatsink the float to keep it's temp. relatively constant while soldering you should get rid of the problem. If there are still gasoline vapours in the float that will make the problem worse. Very nice demonstration.
#5 Kyocum OFFLINE
Kyocum
  • 299 Thanks
  • 424 posts
Posted December 07, 2014 - 08:05 AM
Very cool Alan, I had attempted that kind of repair in the past and could not get past the inside of the float pressurizing when heat was applied. That will be next on my list of things to do. What type of solder are you using? Thanks Kelly
#6 MH81 OFFLINE
  • 29,978 Thanks
Posted December 07, 2014 - 09:10 AM
Good old fashioned 60/40 rosin core. Small enough to be manageable on a project like this.
I would say I had that cube on there for 10-15 seconds before I got the tip and the solder on the float.
A smaller tip like this Weller has is a much better choice IMHO than a trigger gun style.
  • Alc and Kyocum have said thanks
#7 glgrumpy ONLINE
  • 8,815 Thanks
  • 8,014 posts
Posted December 07, 2014 - 11:53 AM
Ha! Better than fella on the PK list who was trying to fix one with a torch!  They told him AFTER, NOt a torch, but sold iron! Was an odd posting hearing his troubles, but kinda chuckled about it too.
#8 New.Canadian.DB.Owner OFFLINE
  • 2,348 Thanks
  • 1,502 posts
Posted December 07, 2014 - 12:31 PM
I have used copper foil / ribbon to cover larger holes.  You can buy it at any stained glass shop.
  • MH81, Alc and LilysDad have said thanks
#9 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,112 Thanks
  • 10,185 posts
Posted December 07, 2014 - 12:53 PM
Alen, you have a very handsome speaking voice. You could hire out to the others of us making videos.
  • MH81 and New.Canadian.DB.Owner have said thanks
#10 johndeereelfman OFFLINE
johndeereelfman
  • 5,730 Thanks
  • 2,603 posts
Posted December 07, 2014 - 01:04 PM
Nice video Alan. You had me a little worried at first though, with the gasoline seeping out of the float, while laying right next to an open flame gas stove burner. Glad it worked out for you, and Thankful for the tip! :thumbs:
#11 MH81 OFFLINE
  • 29,978 Thanks
Posted December 07, 2014 - 01:53 PM
I probably should have mentioned the fire extinguisher in the cabinet next to the stove. Right on about the gas and open flame, thanks for reminding me.
#12 Sawdust OFFLINE
Sawdust
  • 6,154 Thanks
  • 3,548 posts
Posted December 07, 2014 - 07:25 PM
I've done this before using a heat sink & getting the little hole sealed just in time before it blows. Using the ice is a good idea, I think this would give you more time to seal the last hole. Good job on the video too.  :thumbs:
#13 MH81 OFFLINE
  • 29,978 Thanks
Posted December 07, 2014 - 07:49 PM
A follow up: the carb that this went back into runs flawlessly. I was about ready to throw the whole thing into the scrap, but it starts easy, runs great, and the mower is a winner!
  • KennyP, New.Canadian.DB.Owner and Sawdust have said thanks
#14 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,415 Thanks
  • 5,616 posts
Posted December 08, 2014 - 04:00 PM
Good Video on fixing a leaky float.  :thumbs:
