Needed A "heavy Hitch"
10 replies to this topic
#1 WrenchinOnIt OFFLINE
WrenchinOnIt
  • 3,017 Thanks
  • 855 posts
Posted December 06, 2014 - 02:10 PM
Didn't care for the weight box came with the loader for the 3 PTH , so........
Edited by WrenchinOnIt, December 06, 2014 - 08:54 PM.
  • olcowhand, OldBuzzard, grnspot110 and 4 others have said thanks
#2 KennyP ONLINE
  • 32,218 Thanks
  • 42,027 posts
Posted December 06, 2014 - 02:13 PM
Should allow for some 'wheelies'!
  • WrenchinOnIt said thank you
#3 WrenchinOnIt OFFLINE
WrenchinOnIt
  • 3,017 Thanks
  • 855 posts
Posted December 06, 2014 - 02:15 PM
From this to this...... Finished
  • OldBuzzard, grnspot110, case442 and 1 other said thanks
#4 glgrumpy OFFLINE
  • 7,411 Thanks
  • 7,055 posts
Posted December 06, 2014 - 04:45 PM
Pretty nice, and can remove the weights easier when taking off. Would have to lift out or shovel out or whatever on the Box type I suppose? What brand are those weights? Must be for smaller tractors then?  I have a few JD weights I got when I bought blade for mine about like those.
#5 HANKG ONLINE
HANKG
  • 5,518 Thanks
  • 3,047 posts
Posted December 06, 2014 - 05:04 PM
Pretty work !
#6 BNK OFFLINE
BNK
  • 1,054 Thanks
  • 471 posts
Posted December 07, 2014 - 07:07 AM
I always admire nice fab work...well done!
#7 Talntedmrgreen OFFLINE
  • 3,153 Thanks
  • 2,233 posts
Posted December 07, 2014 - 07:38 AM
Very nice!  I had a gift card for Heavy Hitch, and so I used it on one of their products.  Just got it...looks identical to yours, minus the pride of making it!  You did excellent work.  Real nice.  I also like the added utility of this type of hitch, and the more compact size vs the bulky box.
BUT...before taking my weight box off and kicking it aside, I had a few chores to do....now I am loving it as a carryall, and appreciate the fact that I can pile up any old weights or scrap I have to use them as weight.
  • KennyP, WrenchinOnIt and BNK have said thanks
#8 HeavyHitch OFFLINE
HeavyHitch
  • 3 Thanks
  • 2 posts
Posted December 07, 2014 - 10:26 AM
Looks real nice!  Can I ask how long it took to build?  The only thing I see different than ours is the receiver...does is go through the bottom tube or is it welded on the side of the tube?
  • OldBuzzard and WrenchinOnIt have said thanks
#9 WrenchinOnIt OFFLINE
WrenchinOnIt
  • 3,017 Thanks
  • 855 posts
Posted December 07, 2014 - 12:58 PM
Thanks. Receiver butts to the back side centered up , wrap welded , added these just cause I liked the look & a little more strength can't hurt. About 3/4 of a day I guess but I was doing some other stuff as well , probably do better , maiden voyage always takes longer.
#10 HeavyHitch OFFLINE
HeavyHitch
  • 3 Thanks
  • 2 posts
Posted December 07, 2014 - 09:35 PM
Good move adding the gussets!  That will help with side to side and distribute the load more evenly across the surface of the lower tube. Nice job.
#11 WrenchinOnIt OFFLINE
WrenchinOnIt
  • 3,017 Thanks
  • 855 posts
Posted December 08, 2014 - 01:40 AM
Good move adding the gussets!  That will help with side to side and distribute the load more evenly across the surface of the lower tube. Nice job.[/quote
Thank you , your product was my template as you can see & probably guessed , I talked to a gentleman at your company ( perhaps you?) I believe in '11 about your hitch and explained I wanted to make my own , he couldn't of been more helpful and courteous . As you can see by the dates on the photos it took me awhile to get around to it ( weekend warrior,working out of garage). Your hitch I believe was one of the first on the market and see several copycats followed suit. Glad it's made in the USA and you advertise as such , GOOD FOR YOU ! A lot of members on this forum love their stuff and are always looking for attachments that are well made and defiantly serve a extremely useful purpose , I'm sure you read through this post and see props already sent your way by a satisfied customer. You should consider advertising on GT Talk ,become a sponsor ( if your not already ,not sure ,I haven't navigated through entire forum to see). excellent way to further your product's growth into a sure fire market. Thanks for your compliments and help back when I was pondering it's fabrication. Enjoy your Holiday season !
Edited by WrenchinOnIt, December 08, 2014 - 01:46 AM.
  • HeavyHitch said thank you
