Oil For The Diesel
13 replies to this topic
#1 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted December 06, 2014 - 12:43 PM
I'm getting ready to do the first oil change in the Massey so I looked through the book to see what I need. To my surprise, they called for either straight 30 weight or 10W30 for all weather. I thought all diesels took 15W40. Anyone else using 10W30 in their Diesel engine?
#2 KC9KAS OFFLINE
KC9KAS
  • 5,383 Thanks
  • 4,690 posts
Posted December 06, 2014 - 12:53 PM
I don't have a diesel, but I think I would follow the manufactures recomendation.
  • David Brown said thank you
#3 massey driver ONLINE
massey driver
  • 1,422 Thanks
  • 1,576 posts
Posted December 06, 2014 - 01:00 PM
Yeah I started using the diesel 10-30 for a couple years now. I use it summer and winter. When I first started using it I only used the 10-30 in the winter and the 15-40 in the summer. Because I started to buy it by bulk [cheaper this way] its easier to just buy the 10-30 rather then a bit of each..
#4 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted December 06, 2014 - 01:40 PM
Diesel 10-30? Not regular 10-30? I guess I never bought anything other than 15-40 so I wasn't aware there is a difference.
#5 olcowhand ONLINE
  • 41,070 Thanks
  • 31,392 posts
Posted December 06, 2014 - 01:48 PM
I use 15w40 exclusively.
  • David Brown and superaben have said thanks
#6 superaben OFFLINE
superaben
    Con Man
  • 7,668 Thanks
  • 5,677 posts
Posted December 06, 2014 - 02:58 PM
Same here.  That's my diesel oil.
Ben W.
#7 Cat385B ONLINE
    HAZMAT CAT
  • 13,967 Thanks
  • 9,999 posts
Posted December 06, 2014 - 04:03 PM
We run 10-30 in colder weather. That's about 300 diesel engines, I think.
  • massey driver and David Brown have said thanks
#8 Jazz ONLINE
Jazz
  • 2,390 Thanks
  • 1,440 posts
Posted December 06, 2014 - 04:46 PM
X2 on manufacturers recommendation.  Our 900 fleet trucks run 15 40  year round however our reefers run some other oil I can't remember off hand but its not 15 40.
Edited by Jazz, December 06, 2014 - 04:51 PM.
#9 glgrumpy OFFLINE
  • 8,605 Thanks
  • 7,909 posts
Posted December 06, 2014 - 04:48 PM
Rotella is darn good D oil and think it does come in straight 30 too.  It is also for Heavy Duty protection for gas engines. I use it alot in my stuff, not even diesel.  Lots of CASE guys use this oil in their rear axles with good luck.
#10 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted December 06, 2014 - 05:49 PM
Thanks for the advice.  I guess I can use just about anything.  The book calls for either straight 30 or 10W30 for any temperature range.  It says I can use 15W40 as an alternative if the temperature is 14 degrees F or higher.  I think I will see what I can find in Rotella because that's what I've always used in my other diesel and, you're right, it is good oil.  The book seems to like the lighter oil so maybe these newer diesel engines prefer it.  Might make for easier cold starts too.
#11 adamjd200 OFFLINE
adamjd200
  • 2,046 Thanks
  • 2,173 posts
Posted December 09, 2014 - 02:37 PM
We use 30W in our two diesel farm tractors but they are considerably older, I too use Shell Rotella in almost everything.
#12 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted December 09, 2014 - 02:49 PM
I picked up some Rotella 10W30 blend for diesel engines last night.  once I use the tractor again to where it's warm, I'll go ahead and do the 100 hour oil change.  Should be good for when the weather gets colder.  I figure I can't go wrong if it's what the book calls for.  I looked thru the book for my other diesel (1977 Satoh) and found that the oil we've been using since it was new isn't called for in the book.  For that one I'm afraid to use anything else for fear of messing it up!
#13 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted December 12, 2014 - 10:22 AM
I put Rotella 15-40 in my Ford as soon as I got it. I figured if so many over the road diesels were running it  as far back as I can remember it must be good.  I have since  put it in my GT  and both my pickup and car. See no reason to keep more than one oil on hand.
Edited by JD DANNELS, December 12, 2014 - 10:26 AM.
#14 BillTheTractorMan OFFLINE
BillTheTractorMan
  • 205 Thanks
  • 288 posts
Posted December 12, 2014 - 11:44 AM
I run Rotella 15w-40 in everything (gas&diesel) except my vehicles. Old engines run better with it and the extra zinc is good for them. When I my 3/4ton truck hits 200k miles I'm going to switch to the diesel oil.
