Carb Rebuild Problem
7 replies to this topic
#1 bbuckler ONLINE
bbuckler
  • 3,803 Thanks
  • 3,307 posts
Posted December 06, 2014 - 11:51 AM
I'm rebuilding the carb on the 129 but the main jet is stuck I tried wd40 and still nothing any tips on how to remove it ?
  • Sawdust said thank you
#2 Bolens 1000 ONLINE
  • 15,549 Thanks
  • 18,317 posts
Posted December 06, 2014 - 12:08 PM
WD 40 wont be much help, Most of the time on stuff thats really stuck or gummed up I spray out a whole can of carb cleaner into a container and let the carb soak over night.
  • Sawdust and bbuckler have said thanks
#3 bbuckler ONLINE
bbuckler
  • 3,803 Thanks
  • 3,307 posts
Posted December 06, 2014 - 12:09 PM
I'm soaking in vinegar right now.
#4 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted December 06, 2014 - 01:19 PM
Patience is the key on things like this, Like said above soak it overnight is always the best thing to try first..
I  use a screw driver that I ground to fit tight in the jets slot. I also use a screw driver that has a handle that I can put an adjustable wrench on for added leverage.
Now I put the carb in a vice with the jet facing up (if possible),between either soft jaws or blocks of wood,then  I soak the jet with PB Blaster. Put the screw driver on the jet and give the screw driver handle a couple hits with a hammer (to shock the threads) Just don't hit it too hard as to break the carb.
Now put the adjustable wrench on the screw driver handle and while pushing down on the screw driver handle try and loosen the jet, if you get it to move make sure to move it a little in both directions (loosen then tighten). Take your time and tap with a hammer again to shock it a little more.
What ever you try, just be patient. Good luck :thumbs:
  • Alc, HDWildBill, HANKG and 1 other said thanks
#5 glgrumpy OFFLINE
  • 8,848 Thanks
  • 8,035 posts
Posted December 06, 2014 - 05:01 PM
Grind to fit the driver is most important part. If you use too small a tip, will break off the slot edges, and NEVER get it out. Myself don't remove or try anymore after some bad luck on those and just try to soak and clean best I can with that still in carb. NOT the best idea, as there are tiny holes that can plug on that main jet tube, but sometimes if carb was working pretty good, I think leaving it is better choice. I've had to replace carb bodies when I messed them up in past. Sometimes with good fit driver, they just pop loose easy and you are happy, most times doesn't happen that well. Good Luck!
  • HDWildBill and bbuckler have said thanks
#6 bbuckler ONLINE
bbuckler
  • 3,803 Thanks
  • 3,307 posts
Posted December 06, 2014 - 06:21 PM
I did end up leaving it and it runs good.
#7 EricFromPa ONLINE
EricFromPa
  • 4,299 Thanks
  • 3,413 posts
Posted December 06, 2014 - 08:21 PM
I've had very good luck with Boiling old carbs.Even if the jet is seized by corrosion Boiling will remove most of the Gunk and you might not have to remove the jet. Add a little vinegar to the water and let it boil for a good 30 minutes.
#8 jabelman ONLINE
jabelman
  • 2,326 Thanks
  • 1,643 posts
Posted December 06, 2014 - 08:47 PM
I soak them in that berryman stuff had good results. I only had one so far on a flo-jet that snapped on me oh well it happens sometimes. The right size screw driver is a must too.
