Bush Hog D4-12 With Brush Guard
24 replies to this topic
#16 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,371 posts
Posted December 06, 2014 - 04:02 PM
Those Hein Werner hydraulic pumps were used on just about every brand it seems!
Were those optional or standard for these tractors?
Neither. This was made by the original owner. But he did s nice job. What other tractors used this pump?
  • Bolens 1000 said thank you
#17 Bolens 1000 OFFLINE
  • 15,540 Thanks
  • 18,316 posts
Posted December 06, 2014 - 04:04 PM
Bolens,Wheel horse, Cub cadet, Jacobsen
The body and cylinder was the same but the drive pulley and controls were different depending on manufacture
  • sacsr said thank you
#18 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,844 Thanks
  • 2,336 posts
Posted December 06, 2014 - 05:53 PM
I'm glad to see more D4-12s coming onto the radar. What haven't you seen on a D4-10? Did you mean D4-12? And most importantly of all, what are the serial numbers?
Edited by Titus, December 06, 2014 - 05:53 PM.
#19 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,371 posts
Posted December 06, 2014 - 08:25 PM
This D4-12 has a factory bent front axle. I have never seen a bent axle on any of the other D series tractors.
This ones serial number is 226. The range of serial numbers I have collected so far are from 101 to 283.
#20 DH1 OFFLINE
DH1
    Electric Tractors
  • 5,467 Thanks
  • 5,625 posts
Posted December 06, 2014 - 09:35 PM
Good looking tractor and nice find with the grill guard. Maybe the bent front axle was for larger belly mount attachments, mower deck ???
#21 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,371 posts
Posted December 06, 2014 - 09:48 PM
That is what I was thinking to- would make more room for a larger deck.
#22 Texas Deere and Horse ONLINE
  • 14,896 Thanks
  • 15,517 posts
Posted December 07, 2014 - 01:39 AM
Greatfind Scott, glad to see you finally got you a good "12" for your collection Buddy !!
#23 Texas Deere and Horse ONLINE
  • 14,896 Thanks
  • 15,517 posts
Posted December 07, 2014 - 01:43 AM
I notice yours doesn't have the 2nd high/low shift lever under the seat like mine and Peter's has, strange to say the least.
#24 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,371 posts
Posted December 07, 2014 - 06:09 AM
I think where your high low shifter was located is now part of the hydraulic lift. I hope to do some work on it today, will look closer then.
  • olcowhand and Texas Deere and Horse have said thanks
#25 sacsr ONLINE
sacsr
    Bush Hog Addict
  • 3,470 Thanks
  • 3,371 posts
Posted December 13, 2014 - 06:05 PM
No spark so I am betting the solid state is not any good and that is why it has been sitting in a shed the past 20 years. But the D4-10 I bought with the wheel weights, this summer, has good spark, so I will take the solid state ignition off of it.
Had a flat rear tire and swapped it out for a good one I already had. Went back to put the rim back on and it would not fit.......then noticed the hub had been welded at some point. Lucky for me, I had a nos hub with studs on the shelf so it was a quick fix.
Edited by sacsr, December 13, 2014 - 06:05 PM.
  • olcowhand, Texas Deere and Horse, wvbuzzmaster and 1 other said thanks
