Fuel Pump Question.
11 replies to this topic
#1 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted December 04, 2014 - 09:40 AM
As far as I know the aluminum pump is off a k341 and is original. The black pump is aftermarket and is what I'm seeing when I look at new ones. Are the rebuild kits interchangeable? Is one better than the other? I see prices all over the board for these.
#2 glgrumpy OFFLINE
  • 8,505 Thanks
  • 7,856 posts
Posted December 04, 2014 - 07:09 PM
Most kits no longer avail. There was once a fella making kits for them and had a site to show what was offered. There are a few diff gaskets, and three diff type arms used and they determine which style kit you needed. I know this came up in the Power King forum if you search and maybe others have the link saved. Seems it wasn't a tractor place at all, but some kind of antique car parts place that was offering these. Seems around $25?  Cmon guys, help me out here.
#3 superaben OFFLINE
superaben
    Con Man
  • 7,666 Thanks
  • 5,677 posts
Posted December 04, 2014 - 09:24 PM
The place grumpy was talking about seems to have disappeared off the internet!  :wallbanging:
I have the guys phone number, I'll call tomorrow and see what happened to him.
Ben W.
#4 Canawler OFFLINE
Canawler
  • 1,948 Thanks
  • 1,801 posts
Posted December 04, 2014 - 10:57 PM
Here's their site: http://then-now-auto...r-fuel-pumps-2/
The maritime drag racing site just linked to here.
Edited by Canawler, December 04, 2014 - 10:58 PM.
  • superaben said thank you
#5 TokyoDrift99 OFFLINE
TokyoDrift99
  • 81 Thanks
  • 112 posts
Posted December 05, 2014 - 12:56 AM
Get a electric pump from kirk engines. Those kits are NLA as I've found, the pump he sells is great, it only runs at like 2 or 3 psi which is perfect. New mechanical pumps are extremely expensive, and electric ones are better in my opinion.
#6 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted December 05, 2014 - 06:14 AM
50$ for the pump from Kirk engines. I looked at them yesterday. I wondered about that option as well. Thanks for the link.
#7 Canawler OFFLINE
Canawler
  • 1,948 Thanks
  • 1,801 posts
Posted December 05, 2014 - 08:32 AM
Those kits are NLA as I've found...
Kohler and Airtex pump rebuild kits are available from the place I linked to above.
Not to discourage supporting Kirk Engines, but if you're on a budget, low pressure fuel pumps are available lower than that. Mr Gasket sells a Facet made 2-3 psi pump that's available for $37 online and $42 at Advance Auto. Your local Napa store also carries a low psi pump in that price range. There are options even cheaper on EBay. I've been running a $20 generic EBay special pump on my GTX-18 for the last several years with no issues. I want to guess about 150 hours on it so far??
#8 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted December 05, 2014 - 08:44 AM
So any 2 psi pump will work? I've got two tractors needing fuel pumps.
#9 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted December 05, 2014 - 09:24 AM
Something such as this? http://pages.ebay.co...8299297&alt=web
#10 olcowhand ONLINE
  • 39,716 Thanks
  • 30,984 posts
Posted December 05, 2014 - 09:43 AM
Yes, I've bought this pump & having great service from it.  Just be SURE to place the filter BEFORE the pump, as even a small speck of crud can stick the piston in these pumps.
#11 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted December 05, 2014 - 11:05 AM
Thanks for the info guys. I think I'll go the electric pump route.
#12 Canawler OFFLINE
Canawler
  • 1,948 Thanks
  • 1,801 posts
Posted December 05, 2014 - 12:21 PM
Just make sure the tractor's electrical system is up to it. The pumps won't draw much current but most GT charging systems don't have much extra capacity. On my GTX-18, if I have all four lights on, the pto coil on, and the cruise control coil on, the extra load of the pump puts it into discharge a little bit.
