Mf10 Or Mf12 W/ssi Ignition Switch
8 replies to this topic
#1 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 04, 2014 - 07:13 AM
Which one is the correct one?
Is it this one from Stens?
  • Sawdust said thank you
#2 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted December 04, 2014 - 08:00 AM
Looks like the pin out is right with the M on there, but you want to double check before installation. Mainly, no power to the M pin and it shorts to ground when off.
Edit: I did a little parts looking and Sears calls for a 3492r or 583732501 for the ST16.
  • IamSherwood said thank you
#3 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 04, 2014 - 08:20 AM
I have the original 4 pin switch that is labelled as in the wiring diagram.
The kill wire comes from the "D" pin, and the body of the switch is grounded.
The other pins are "B" battery
                              "S" solenoid
                                "C" charge circuit
correct?
What does "D" stand for?
#4 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted December 04, 2014 - 08:30 AM
Never noticed a switch with a "D" pole!  A switch with an "M" is correct though, as it stands for magneto & is a grounding circuit.
  • limebuzz and IamSherwood have said thanks
#5 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted December 04, 2014 - 09:46 AM
Here's a wiring diagram from a later manual, MF12g, dated 1974.
Edited by DH1, December 04, 2014 - 09:48 AM.
  • MH81, IamSherwood and Sawdust have said thanks
#6 Sawdust OFFLINE
Sawdust
  • 6797 Thanks
  • 3799 posts
Posted December 04, 2014 - 11:37 AM
Will my 1968 MF12 has the same switch your showing from Stens obviously not original as the manual shows the same 4 pin switch your showing. Mine never did charge so maybe this had something to do with it. I too don't know what the D pole is for.
#7 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 04, 2014 - 01:04 PM
I had 2 of them with the "D" pin. They wouldn't hold the key when in the off position, so
I changed them out with new ones that I bought from MF dealer. I don't have those ones
handy at the moment, but will look at them soon.
They check out to work in the circuit here.
If using this switch, there is no pin for the DC wire from the regulator. I suppose it could go to
the "L" pin, and work properly. Am I right here?
Jim, how was your DC wire dealt with? Your reg could have been the problem too.
#8 glgrumpy OFFLINE
  • 9100 Thanks
  • 8195 posts
Posted December 04, 2014 - 07:04 PM
D is for DONE!  Stops tractor when done using. :smilewink:  L on most switches if for Load or Lights and runs those items when key is on. M poles are needed for Magneto equipped tractors and NOT battery ignition. It is a ground. These are little odder marked switches, not familiar with those, but would bet same as some others, just odd labels we don't usually see.
#9 IamSherwood OFFLINE
  • 8411 Thanks
  • 7697 posts
Posted December 04, 2014 - 08:05 PM
Metric maybe Eh? :smilewink:
