Ht22 2288
32 replies to this topic
#16 nglauer OFFLINE
nglauer
  • 458 Thanks
  • 379 posts
Posted December 05, 2014 - 06:21 PM
There is another member on the page (also from Norway) with an HT22
#17 nglauer OFFLINE
nglauer
  • 458 Thanks
  • 379 posts
Posted December 05, 2014 - 06:22 PM
It's the same guy, he was having starter problems
#18 nglauer OFFLINE
nglauer
  • 458 Thanks
  • 379 posts
Posted December 05, 2014 - 06:25 PM
Andreas Aasvang on the Bolens Lawn Tractor Group also owns an HT22.
#19 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted December 05, 2014 - 06:29 PM
Magnus Munkelien‎ on the Facebook Bolens Lawn Tractor Group has an HT22
https://www.facebook...958613/?fref=nf
Here are a few pictures that he posted today
He added photos I have not looked to see if he did yet I asked him to.
#20 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted December 05, 2014 - 06:30 PM
This is probably the same machine... what are the odds someone else puts tire chains on the front of their tractor that look like that.
It is... :D
  • Bolens 1000 and nglauer have said thanks
#21 nglauer OFFLINE
nglauer
  • 458 Thanks
  • 379 posts
Posted December 05, 2014 - 06:45 PM
So... is there really a difference in an HT22 and a HT1000?
#22 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted December 05, 2014 - 07:09 PM
HT22 is the same tractor as the HT20D.   HDT1000 has only the same rear as those two... Frme, engine and most of the rest are not the same other then some of the simple stuff on all 3.
  • Bolens 1000, blackjackjakexxix and nglauer have said thanks
#23 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted December 06, 2014 - 11:12 AM
Yes and no.  It all depends on how picky you want to get :D :D :D
There are differences, but they are minor.
There were two models of the HDT1000.  2388 and 2388s.  The 2388 was built in 1982 and 1983. The 2388s in, probably 1984 and possibly 1985.  That's speculation as I have found nothing that actually references the 2388s other than the fact that it's printed on the OOM and Parts Manuals. Other than on the front cover, the OOM never references the 2388s, and all illustrations are for the 2388.  The parts manual is pretty much the same other than the fact that they tacked on a parts list for the PS as the last page of the manual. There are no footnotes indicating differences for parts between the 2388 and 2388s
For the 2388, other than the engine, the biggest would be factory Cruise Control, the longer hood, a different fuel tank, battery location, and a fishplate bolted to the front of the frame to support the fuel tank. I would assume that there would have been different cutouts in the frame to accommodate the engine. An engineering note does say "stronger frames".
For the 2388s, it appears that they added factory PS, an auxiliary hydro oil cooler, and different decals.
I gave Jerome a book that contained internal engineering notes from Bolens, and he found a reference to the HDT1000.  On that sheet, they referred to it as the HT23D.
He was kind enough to send me a picture, which I'll attach here.
The biggest noticeable difference, other than the engine, is the travel speed  The HDT1000 will zip along at 13 Mph!  I'm assuming that Bolens did that because the folks overseas tend to drive their GTs on the road and they wanted a good speed for that.
  • WrenchinOnIt said thank you
#24 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted December 06, 2014 - 11:52 AM
Yours OB is a 2388S-01 That was built starting in 4-15-83 from what info I have found in the rest of that paper work.  Those two books you still have dont happend to have more engineering changes do they? What you gave me starts at 225 I would think any number under 225 would have info on like on the tubes and large frames from the 60s because the were modal with number like 197 and 198.
#25 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted December 06, 2014 - 12:01 PM
You got all of the engineering notebooks I had.
The ones I kept have attachments information.
If you found more notes on the HDT1000, would you be so kind as to scan/take a pic of it/them for me?
Edited by OldBuzzard, December 06, 2014 - 12:03 PM.
#26 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted December 06, 2014 - 12:03 PM
Are those like one page pages like what you gave me?
#27 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted December 06, 2014 - 12:34 PM
No, they are all brochures, parts and owners manuals, price lists, correspondence with manufactures, etc.
It's mostly the "Allied Manufactures".
#28 LPBolens OFFLINE
LPBolens
  • 1461 Thanks
  • 979 posts
Posted December 08, 2014 - 11:40 PM
What problem is he having with the starter? The one on my HT20D had a bad bendix, but after lots of searching my local auto electric repair shop was able to find one somewhere in Canada.
Edited by LPBolens, December 08, 2014 - 11:41 PM.
#29 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted December 08, 2014 - 11:50 PM
Doug he seems to have it fixed now but thanks for the help.
#30 accidentalchild OFFLINE
accidentalchild
  • 382 Thanks
  • 463 posts
Posted June 15, 2015 - 07:48 PM
I want one.
  • Clevis said thank you
