Hydraulic Seal Question.... Help
11 replies to this topic
#1 tweidman OFFLINE
tweidman
  • 251 Thanks
  • 797 posts
Posted December 03, 2014 - 12:58 PM
I took my hydraulic steering cylinder apart because it was leaking. The control valve seal seems to be the problem. The seal that is leaking has a square shoulder, but I could only find and O ring replacement. Will an O ring work? If not, where do I find a replacement, the dealer says it's No longer available.
Edited by tweidman, December 03, 2014 - 03:10 PM.
#2 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted December 03, 2014 - 01:55 PM
an o-ring will most likely work as long as it fits in the slot. the oring will compress some when tightened down and fill in the gap.
#3 tweidman OFFLINE
tweidman
  • 251 Thanks
  • 797 posts
Posted December 03, 2014 - 03:14 PM
There is a grove that it fits into and then the shaft runs though the inside of the seal. So, nothing gets tightened down.
The O ring does fit the shaft tighter than the old seal. I'm just wondering if it will seal and wear the same as the old part.
 I'm not sure how the old squared off part compares to the round O ring in it's ability to hold the pressure and seal the fluid?.
Edited by tweidman, December 03, 2014 - 03:24 PM.
#4 olcowhand OFFLINE
  • 40,350 Thanks
  • 31,170 posts
Posted December 03, 2014 - 03:20 PM
It should do fine.  It may not last quite as long as the square one simply because the o-ring has less surface area to seal & fight wear.  I have replaced many square rings with o-rings & they have always performed well.
  • tweidman said thank you
#5 tweidman OFFLINE
tweidman
  • 251 Thanks
  • 797 posts
Posted December 03, 2014 - 03:24 PM
That's good to hear. Now that I made a tool to get it apart, it won't be that hard to replace if it starts leaking again. I'll try it and see what happens.
#6 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted December 03, 2014 - 04:11 PM
Your safest bet is to go to a hydraulic shop and order quad rings I replaced the lip Seals in my bolens vales with the
And I would recommend going that Route
#7 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,914 Thanks
  • 2,451 posts
Posted December 03, 2014 - 04:13 PM
 where do I find a replacement?
Here is a source: http://www.theorings...ex&cPath=367_98
More than likely, the shipping will cost more than the parts.
  • tweidman, Alc, HANKG and 1 other said thanks
#8 KC9KAS ONLINE
KC9KAS
  • 5,324 Thanks
  • 4,670 posts
Posted December 03, 2014 - 07:39 PM
This is what I would recommend...Go to a hydraulic shop for the correct parts.  :iagree:
Edited by KC9KAS, December 03, 2014 - 07:39 PM.
#9 skyrydr2 ONLINE
  • 3,870 Thanks
  • 3,403 posts
Posted December 04, 2014 - 04:25 AM
Don't use an o- ring .... Its edges are round and thus allow dirt to get jammed under it. That seal needs sharp edges to keep it clean and free moving.
A good hydraulic shop is your best bet.
#10 olcowhand OFFLINE
  • 40,350 Thanks
  • 31,170 posts
Posted December 04, 2014 - 08:36 AM
Many cylinders come factory with simple o-rings.  No doubt though that square are a bit better.
#11 Canawler OFFLINE
Canawler
  • 1,948 Thanks
  • 1,801 posts
Posted December 04, 2014 - 09:43 AM
McMaster-Carr is another good source for square o-rings.
#12 tweidman OFFLINE
tweidman
  • 251 Thanks
  • 797 posts
Posted December 04, 2014 - 11:20 AM
Thanks guys. I think I will try to find the square O ring locally before I put it back together.
Although I don't think dirt will be much of an issue where this seal is located. It is not directly exposed to the elements.
