Snocaster 18538
18 replies to this topic
#16 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 5127 Thanks
  • 2912 posts
Posted November 30, 2014 - 07:29 PM
Thanks much.  Now I kind of have an idea what to look for when I get into mine.  Don't know the numbers of mine as I can't read them any more.  Tag is about gone completely from being outside for 10 years or more.  I found a manual but it is for the newer style.
Rog
http://gardentractor...ster-partslist/
  • Bolens 1000 said thank you
#17 Husky OFFLINE
Husky
  • 1509 Thanks
  • 1202 posts
Posted November 30, 2014 - 08:14 PM
Hi I have replaced these bearings in the past on my tube frame blower. I am in the process of replacing a set on an eliminator snowcaster which I think may be the same bearings just the flange is different. They are common bearings. The bearing is the only piece you really need. The outer flange can be removed from the old bearing and reused unless you had to destroy them to get it apart which sometimes happens.  I am researching the part numbers. I can post here when I find them or feel free to send me a PM.
#18 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted December 02, 2014 - 06:31 PM
Got the bearing 1185898 and flange interchanged and now stock them.
I will probably sell them as a set like Bolens originally did.
These ones are an upgrade over the originals and have a grease fitting on them for extended life, should outlast the originals by far!
Special Price to GTT members $ 29.95
  • sodisr said thank you
#19 sodisr OFFLINE
sodisr
  • 663 Thanks
  • 773 posts
Posted December 03, 2014 - 09:14 AM
Got everything I needed to re=assemble my sno caster..  I found the parts at my local Farm and fleet.  ( simular to Tractor Supply  )
This is for the Tube-Frame   snocaster  Model  #  18538-01
The self-aligning sprocket bearing------  Pt. #  SA204-12---   $ 8.99
Inter-change bearings-----------------------AGRI-TEST--- SA204-12
                                                               BCA------------NPS-012-RRO
                                                               FAFNIR-------RAO12RRB
                                                               PEER----------FH204-12
The housing alone                                 P204                     PP204
                                                               LP204                   PF204
                                                               FS204                   PFL204
                                                               PFL204G
#  40 chain            10 FT           $ 11.99
  I also went to Applied Industrial Technologies
           Their price           Bearing----------------#     FAFN RAO12RR       $23.81
                                     Bearing and flange   #     AMI KHFL204             $27.18
                                     Sprocket                   # Martin-40BS13- 3/4         $16.23
NOW on to putting it all back to gather ... :smilewink:
