Bolens 1250 to kubota power
135 replies to this topic
#76 Cvans ONLINE
  • 7,289 Thanks
  • 6,378 posts
Posted September 16, 2011 - 09:21 AM
Hey Hammer, any more progress on this project? You've done a fantastic job so far and I can't wait to see what you have been up to.
#77 Cvans ONLINE
  • 7,289 Thanks
  • 6,378 posts
Posted September 16, 2011 - 09:24 AM
Daniel:
Were did you locate the chart for this engine. I would like to see if there is information available for other other engines.
#78 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted September 16, 2011 - 10:19 AM
Daniel:
Yes, more info there: Kubota Diesel Engine Super Mini series - Model Z482
  • Cvans said thank you
#79 Cvans ONLINE
  • 7,289 Thanks
  • 6,378 posts
Posted September 16, 2011 - 07:31 PM
Thanks!
#80 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted September 16, 2011 - 08:21 PM
I haven't had the time to work on it this past month. Hope to get back on it this weekend. thanks for the interest
#81 fordmustang1984 OFFLINE
fordmustang1984
  • 24 Thanks
  • 428 posts
Posted September 18, 2011 - 02:38 PM
Hey Hammer, sweet diesel build! I've got my own, and cant seem to find the info on wiring the alternator, which appears to be the same as yours?
#82 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted September 18, 2011 - 05:37 PM
i havent had the time to check into that yet. the one i bought is off a tg1860 so i bet a wiring diagram from that machine would help.
I like the mini dozer you have going on. once this machine is completed that will be one of my next projects
#83 fordmustang1984 OFFLINE
fordmustang1984
  • 24 Thanks
  • 428 posts
Posted September 19, 2011 - 03:40 PM
Thanks, its been one of my faster projects. Just a few more parts for a test drive now. I'll see if i can find a diagram for that so we have two pairs of eyes searching.
#84 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted September 22, 2011 - 06:57 PM
finally got something done on the 1250.
Mounted up a power steering cylinder. I bought this through baileynet.com. 3 3/4" stroke works just right.
i cut the ball end off the rod side and welded the original steering rod to it
Heres a few pics
#85 olcowhand OFFLINE
  • 42,898 Thanks
  • 31,941 posts
Posted September 22, 2011 - 07:05 PM
Looks great Hammer! With the power steering, I've found those type tie rod ends sometimes don't hold up too long. I replaced mine with female heim joints that match the threads on my control arms. Very easy/fast/dependable fix.
#86 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted September 24, 2011 - 04:25 PM
Daniel, Ill keep that in mind. No big deal to change it over when it wears out.
Ill be working on mounting the steering valve, 2 three spool hydraulic valves and the 8 hydraulic quick couplers next.
#87 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted October 09, 2011 - 02:49 PM
how did you make the stub shaft to go to the driveshaft? thats the problem im going to have with my z751a kubota in my ht20. also how many hours is on your kubota engine?
#88 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted October 09, 2011 - 06:01 PM
I bought some 1" keyed shaft and drilled a hole into the center of a 1/2 plate. slid the shaft through the back of the plate about 5/8" and welded it up. i faced the back of the steel plate on the lathe and turned the flywheel side of the shaft down until it slid into the hole in the middle of the flywheel. Drilled the bolt pattern and bolt it up.
Hours on my kubota are unknown. It was in a golf course machine. they way it runs id say over 4000hrs but who knows how its been cared for. it will be getting a rebuild soon enough
I have since changed to a different stub shaft since i cut my cross shaft for the hydro pedal out of the way. im going to try and make an independent rear pto. Im thinking 1-1 chain drive off the flywheel stub shaft. a 3/4" shaft will run right above the framerail on the right side of the tractor with a 3" double goove pulley on the end. Ill have a 1" 15spline pto shaft in the middle of the tractors rear with 2 bearings and a 6" double groove pulley. Im thinking i can put a lever mounted to a tensioner pulley to turn the pto on and off. Ill need to make this work around the 3 point im going to build as well. any ideas on any of this would be great
I bought a different steering valve from a 345 deere. It fits into the steering column much better and has side ports. I made the bracket to mount that up today. Im probably going to end up making the port adapters to work with this valve also. It uses a "port-o" system.
I also started making the handle assembly for the dash mounted 3 spool valve. I picked up a hydraulic hose crimper so ill be making my own hoses too.
#89 Guest_jdecker94_*
Guest_jdecker94_*
  • Guests
Posted October 09, 2011 - 06:05 PM
alright, i have a hole in my flywheel i was wondering how incorporate that. how would you decipher that a diesel has high hours? lots of black smoke?
#90 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted October 10, 2011 - 04:21 PM
Black smoke is normal at startup and under load. my diesel blows tons of oil out of the exhaust and crankcase vent. have yet to tear it down to determine the cause
