Bolens 1250 to kubota power
135 replies to this topic
#46 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted June 20, 2011 - 03:16 PM
more parts
precleaner for the air filter and my power steering cylinder
#47 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted June 25, 2011 - 08:01 AM
Made the lower radiator hose this week out of some 1" copper pipe. I think i might add a port in it for the fan control switch. the port near the thermostat will be used for the temp sensor.
I have an orbital valve for the power steering coming.
Decided on a different set of gauges and a layout for the new dash
Alternator is here. I didnt want to use the dynamo that came with the engine and the new alternator is cheaper than the regulator i needed for the dynamo system.
Trying to find a part number for a tach/ hourmeter off a kubota mini excavator. The one i bought is only 3000rpm and 3 digit on the hourmeter which i didnt know when purchased it. Im hoping to find one thats 3600rpm and 4 digit hourmeter
#48 olcowhand ONLINE
  • 41,004 Thanks
  • 31,367 posts
Posted June 25, 2011 - 08:09 AM
Thanks for the update. Things are coming along. Looking forward to more!
#49 bhts OFFLINE
bhts
  • 1,472 Thanks
  • 2,165 posts
Posted June 25, 2011 - 08:57 AM
That is a nice job your doing there. Be glad to see the finished project when you get it done.
#50 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted June 25, 2011 - 04:38 PM
heres the lower hose i made. im going to add a port for the electric fan switch and the added length should make it sit more level with the frame.
This is the injector return line going back to the tank.
Today i made the throttle and fuel shut off contols. The larger handle is the throttle. fully forward is idle and all the way back is wide open. Ill add the rubber grips like the pto and park lever have so everything matches
I also ordered a new tachometer/hourmeter from a L2050F kubota.
It feels good to make some progress again!!!!
#51 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted June 26, 2011 - 03:38 PM
mounted the air cleaner and made the intake piping. I think i have to find a rubber 90*fitting and i can eliminate the part that jogs out above the throttle linkage. The precleaner will be located above the hood but i want to wait until the dash is made and the hood is extended before i drill the hole.
Also got the electric fan mounted today
This morning i picked up some brake rotors, calipers and a section of a hood to extend mine
Throttle linkage video
Edited by hammerdwn20, June 26, 2011 - 04:17 PM.
adding video
#52 olcowhand ONLINE
  • 41,004 Thanks
  • 31,367 posts
Posted June 26, 2011 - 06:27 PM
Looks like you can really run her now!
#53 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted June 30, 2011 - 04:33 PM
New tach came today. i like this one much better.
Got the power steering valve earlier in the week and i have some different rear hubs coming for the steering brakes
#54 olcowhand ONLINE
  • 41,004 Thanks
  • 31,367 posts
Posted June 30, 2011 - 04:59 PM
How much was that tach, and is it electronic or cable? That's a slick looker!
#55 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted June 30, 2011 - 05:25 PM
ITs cable operated. Part # 35260-34602 got it for 91.60 plus shipping
#56 olcowhand ONLINE
  • 41,004 Thanks
  • 31,367 posts
Posted June 30, 2011 - 05:35 PM
I don't think my D1005 has a drive fitting for a tach. I'll have to give a look-see.
#57 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted June 30, 2011 - 06:07 PM
if it doesnt its easy to add on. the tach drive is driven off the fuel camshaft on the front of the motor. i think thats about 45$ if you need it. the cable im using is part # 67800-55410 and is 17.90$
#58 olcowhand ONLINE
  • 41,004 Thanks
  • 31,367 posts
Posted June 30, 2011 - 06:23 PM
I just remembered....I have NO room in my dash for a tach! LOL
#59 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted June 30, 2011 - 06:26 PM
[ATTACH=CONFIG]16665[/ATTACH]
ah thats no excuse Daniel! You dont need the hourmeter anymore because the tach has one. it actually quite small. it fits in the palm of my hand
#60 1adamb OFFLINE
1adamb
  • 2 Thanks
  • 38 posts
Posted July 04, 2011 - 06:58 AM
Just found this thread. Wanted to say awesome work. I have a spare parts tractor with complete frame.... you've given me ideas :)
