Bolens 1250 to kubota power
135 replies to this topic
#31 Bolens 1000 OFFLINE
  • 14,986 Thanks
  • 18,140 posts
Posted March 06, 2011 - 08:58 PM
Looks like the project is coming together :bounce: NICE
#32 Texas Deere and Horse OFFLINE
  • 14,800 Thanks
  • 15,495 posts
Posted March 06, 2011 - 09:22 PM
That project is coming along very well. Your work looks GREAT !!!
#33 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted April 03, 2011 - 12:53 PM
new kubota ignition switch. 15$ from ebay
[ATTACH]12621[/ATTACH]
new donaldson air cleaner assembly 40$ shipped from ebay
[ATTACH]12622[/ATTACH]
I put the pto adapter on the lathe and trued the mounting flange. Im using stock length belts
[ATTACH]12623[/ATTACH]
I made this adapter for the driveshaft to bolt to the flywheel. It has a pilot that slides into the hole in the flywheel like a transmission input shaft does.
Yokes are weasler 6n
[ATTACH]12626[/ATTACH]
Slip yoke with 3/4 by 7/8" bar shaft. Im going to see what i can find for a hydro fan. If i cant find anything ill get a conversion u-joint to go from 6n to n1000 then reuse the old yoke and fan from the original driveshaft.
[ATTACH]12625[/ATTACH]
Started making some brackets to mount the radiator out of angle iron. Getting closer to a test run!!!!!
[ATTACH]12624[/ATTACH]
#34 olcowhand OFFLINE
  • 41,093 Thanks
  • 31,402 posts
Posted April 03, 2011 - 01:11 PM
Hammer, I didn't even put my hydro fan back on my driveshaft. Cumbersome to install & I have hoses running close by, so opted to drop it & just add an oil cooler. If your tractor's hydro is ported, then you can just take the return line through a cooler before it re-enters the reservoir. Looks like you have plenty of room for a cooler on the dash side of your radiator.
And as to your work so far....superb! How old/young are you again? Great work for any age!
#35 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted April 03, 2011 - 01:28 PM
Daniel, I like that option. Ill have to see what kind of room is left after the power steering valve is in there. i still need to purchase one. I was also throwing around the idea of a hydraulic rear pto over a mechanical one. still not sure what direction im going with that.
Im 24. thanks for the kind words.
Frank
#36 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted April 05, 2011 - 04:40 PM
Didnt get any work done on the tractor today. i kind of just stared at it for a while. i did order some more parts for it though. exhaust manifold and fuel filter. a few covers i needed for the engine too.
This project will be on hold shortly until i repair the engine in the massey 2924d and get it sold
#37 olcowhand OFFLINE
  • 41,093 Thanks
  • 31,402 posts
Posted April 24, 2011 - 06:38 PM
Where ya been hammer? Any more done on the project? Been 2 weeks, so figure you've done more wrenching/fabbing.
#38 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted April 25, 2011 - 03:44 PM
haven't had any time to work on it. probably wont be able to so anything for a while. i need to get the 2924d back together and sold first so i have a little garage space again
#39 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted April 30, 2011 - 04:28 PM
rigged up a temporary exhaust and steering
Fuel filter bracket
Resealed the oilpan and put a block off plate where the hydraulic pump was mounted to the fuel camshaft.
I hope i can get a video of it running for you guys tomorrow!!!!
#40 mjodrey OFFLINE
Posted April 30, 2011 - 05:40 PM
That is looking good.:thumbs:
#41 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted May 01, 2011 - 10:56 AM
#42 Texas Deere and Horse OFFLINE
  • 14,800 Thanks
  • 15,495 posts
Posted May 01, 2011 - 11:41 AM
Very nice repower job, It looks great, those kubota's are hard to beat...
#43 olcowhand OFFLINE
  • 41,093 Thanks
  • 31,402 posts
Posted May 01, 2011 - 11:45 AM
She sounds great hammer! I know you're itching to get to really work her!
#44 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted May 01, 2011 - 11:50 AM
i am but its a long ways off. I still need to add power steering, individual turning brakes, gauges and dash panel,wiring, lengthen hood, lengthen the pto rod, build a three point hitch with its own hydraulic cylinder, front and rear hydraulic hookups hydraulic oil cooler and paint.
The engine seems to run better than i remember so maybe ill run it the way it is for a while instead of rebuilding it right away.
Then i still have to go through all the attachments as well as a few i would like to make for it. Its a fun project so far
#45 hammerdwn20 OFFLINE
hammerdwn20
  • 126 Thanks
  • 283 posts
Posted June 13, 2011 - 04:12 PM
Not much of an update. Been super busy but hope to get back at it soon. Ordered some parts. Factory kubota tach/hourmeter and the drive cable. also ordered the see through pre cleaner assembly for the air filter but didnt recieve it yet
