For Sale
K-161 .010 Build, Fine Spline Rear & Other Cc Parts
No replies to this topic
#1 BNK OFFLINE
BNK
  • 1,095 Thanks
  • 495 posts
Posted November 30, 2014 - 04:20 AM
For sale: K-161 7 hp Kohler .010 build w/25-30 hrs run time. Never powered a mowing deck just did some pushing w/a front blade. Removed from my wife's 62 Original I parted. Nice correct and sweet running replacement engine. Comes as you see it (coil & plug wire included). Recent carb rebuild w/no play in the throttle shaft. Drop in turn key. $300
For sale is a low hour 31mm fine spline rear from a 1810 CC. Clean & no shavings were found. $100
Please local PU only. 37186 zip code on the Tenntucky line~
Shifter plate correct for Original,70/100,71,72 & 73 CC. No side to side slop, good gasket and IH stamp hardware. $25 + shipping.
Gear reduction housing from a 62 CC ser# 26727, no leaks or noises before removal. $40 + $18 shipping.
FREE! To a good home only if you buy the engine. 1 uncracked frame and front axle, 2 rear ends one complete w/gear reduction (unknown) the other is missing the reduction housing & shifter plate...carrier bearing is down but shifted good. All from a Original CC 61-63. And various small parts I can find for/from a 61-63 Original.
  • superaben said thank you
