Ht20 Bare Frame Resto
9 replies to this topic
#1 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5112 Thanks
  • 1215 posts
Posted November 29, 2014 - 12:50 AM
This has been a project that I have vowed to finish this winter ( I think) . Anyways this has a ton of new parts and I have no excuses for not finishing. Rear end all new with NOS parts except bearings and bushings, they are after market. Robert Mann from Sonny's was a huge help and supplied the parts problem free ( it was '08 thou) I was sorry to read of his hardships. The Sundstrand pump went out for a total rebuild (ouch!) and the engine has everything new in it except the block, crank, jugs, and manifolds. yep new cam, valves, springs, tappets, governor, carb, forged pistons and  rods ( that's right forged) oil pump, heads etc.(double and triple ouch!!) tractor has NOS hydro cooler, custom bent SS hydro lines, powder coated engine tins, battery/gas tank bracket, foot rests, firewall, top heat shield & air cleaner. all new bolts, bushings, bearings, races, & seals.
  • Bill56, blackjackjakexxix, Moosetales and 6 others have said thanks
#2 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5112 Thanks
  • 1215 posts
Posted November 29, 2014 - 12:54 AM
more pics
  • blackjackjakexxix, sacsr, Moosetales and 4 others have said thanks
#3 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5112 Thanks
  • 1215 posts
Posted November 29, 2014 - 12:58 AM
more.....
  • Bolens 1000, blackjackjakexxix, sacsr and 7 others have said thanks
#4 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted November 29, 2014 - 07:58 AM
Looking through the pics, I seen something I covet.
How do you like having a floor drain? Is it hooked into a storm or sanitary line? Or does it daylight outside? Do you have a trap and/or cleanout on it?
  • Bolens 1000 and WrenchinOnIt have said thanks
#5 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5112 Thanks
  • 1215 posts
Posted November 29, 2014 - 09:07 AM
Trapped, ran into storm drain , with a clean out outside because of how it intersects into my drains.
  • Cat385B and Traill95 have said thanks
#6 Little Irish Men OFFLINE
Little Irish Men
  • 848 Thanks
  • 477 posts
Posted November 29, 2014 - 09:13 AM
That's very nice  that's alot of work i know i am almost done with mine . Please let us see it when it is all finish.
  • blackjackjakexxix and WrenchinOnIt have said thanks
#7 Rainier OFFLINE
Rainier
  • 682 Thanks
  • 557 posts
Posted November 29, 2014 - 02:02 PM
Where did you send your hydro for repair? I may be needing some of that?
#8 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5112 Thanks
  • 1215 posts
Posted November 29, 2014 - 06:38 PM
Hydrostatict Transmission Repair LLC  Tupelo MS . Pricey but supposed to be good, can't tell you cause I haven't run it yet. BJ Hydraulics in MI told me they no longer rebuild them but put me in contact with who they recommended, (close to their area if I remember)  sorry can't find that info, I'll try to look asap. Have another place I'll post the info Monday if you want
  • Bolens 1000, blackjackjakexxix and Sawdust have said thanks
#9 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted November 29, 2014 - 11:44 PM
Did you talk to the old man at BJ if you did how long ago was it I just seeing if he is still around?  I have not talked to him in years.
#10 WrenchinOnIt OFFLINE
WrenchinOnIt
    Got Sum
  • 5112 Thanks
  • 1215 posts
Posted November 30, 2014 - 07:29 AM
Can't say if he was the "old man" or not , but whoever it was steered me to the other place phone number and all , that place (still have to look for ) said "put in a box send it out , we'll tear it down give you an estimate and go from there"  sounds fair. Place in Tupelo was a set price for a total rebuild
  • Sawdust said thank you
