Moto Mower For Missing Parts.
11 replies to this topic
#1 TomLGT195 OFFLINE
TomLGT195
  • 3,697 Thanks
  • 2,761 posts
Posted November 28, 2014 - 04:07 PM
I picked this up today. It isn't the model I have but the parts I need are the same. Battery cover, lower hood piece,seat, and tires are in great shape. The motor is a Briggs , not sure if it's original , don't even know if it turns over.
I'm not sure which model or year it is but the confusing thing is the stamped steel footrests that work like the older cast ones. Mine are stationary. Maybe it's the year things started to change over.
Sorry ,I'll post more pics tomorrow. Long drive today
One other thing might be on the older model, a hand brake behind the axle.
Tom
  • MH81, Alc, IamSherwood and 3 others have said thanks
#2 jabelman OFFLINE
jabelman
  • 2,163 Thanks
  • 1,559 posts
Posted November 28, 2014 - 04:25 PM
Never seen one with a handbrake? Usually they have the clutch / brake pedal. Neat little tractor
  • TomLGT195 said thank you
#3 TomLGT195 OFFLINE
TomLGT195
  • 3,697 Thanks
  • 2,761 posts
Posted November 28, 2014 - 04:28 PM
Here's the pics he sent me.
  • Alc and CRFarnsworth have said thanks
#4 CRFarnsworth OFFLINE
CRFarnsworth
  • 4,587 Thanks
  • 2,111 posts
Posted November 28, 2014 - 05:45 PM
Looks to be a first cousin to a MF Executive.  Rick
#5 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted November 29, 2014 - 11:46 PM
Dura (parent of moto-mower) made the MF Execs.  The hoods are different.
Does the motor appear to be original?  Date code in the picture starts with (19)65.
It is possible that it is a combination of parts from multiple years - earlier tractor with later foot pedal.
If it's a combination of parts, that may be a good thing if you plan to use it for parts.  You aren't breaking down a good one.
I've seen the hand brake on earlier moto-mowers.  Mine have a "J" hook that holds the clutch/brake lever.  The "J" hook wouldn't work for the ones with the moving pedals.
#6 IamSherwood OFFLINE
  • 8,390 Thanks
Posted November 30, 2014 - 01:12 AM
That's an interesting find Tom. Is there a ID tag on it somewhere? Behind
the dash maybe.
In terms of being a cousin to the MF Execs, it's quite a combination of parts.
Here's what I can spot. In comparison to Exec parts.
Steering wheel 1963
Seat 63
Deck 63
Rear parking brake handle 63 & 64
Hood latches on sides 63
Ignition switch in bat cover 63
Flat drive belt tensioner above belt 63
Front axle and steering arms 63
Sheet metal over frame has cut outs on sides for lift lever 64 & 65
Checker plate foot rest/pedal 65
Hood has cut outs on sides, with ridges above 65
Interesting.
Throttle and choke in dash 64 & 65
  • motobreeder, CRFarnsworth and TomLGT195 have said thanks
#7 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted November 30, 2014 - 07:35 PM
will,
I agree the grill looks like 1963 moto-mower.  Shortly after the transition from Porter-Cable.
I'm not sure the steering wheel is as limited range.  The cast aluminum steering wheel was on later models.  I believe this one is a 1966 (based on the code on the motor).  Is there a change in shapes?
So far, the more I've learned about moto-mower, the more I'm guessing the factory did a bit of "this and that" using parts that were on the floor.
  • CRFarnsworth and TomLGT195 have said thanks
#8 IamSherwood OFFLINE
  • 8,390 Thanks
Posted November 30, 2014 - 08:33 PM
Hi Dwayne.
All those dates and parts I listed above refer to MF Execs. As in, on the execs, that
aluminum steering wheel was only used in 1963.
In your researching of Moto-Mower, has the name Johnny Cash come up at all? :smilewink:
https://www.youtube....h?v=rWHniL8MyMM
#9 motobreeder OFFLINE
motobreeder
  • 433 Thanks
  • 618 posts
Posted November 30, 2014 - 08:55 PM
Will - good one on the video/song - a classic.
It seems like the 1960s was the heyday of lunchbox wholesale.
Maybe this one is a rare factory original. ;)
#10 jabelman OFFLINE
jabelman
  • 2,163 Thanks
  • 1,559 posts
Posted November 30, 2014 - 09:22 PM
Yeah it would be cool to redo it. Someday would like to find one to add with the porter cables its neat how the design evolved
  • Alc and TomLGT195 have said thanks
#11 TomLGT195 OFFLINE
TomLGT195
  • 3,697 Thanks
  • 2,761 posts
Posted December 01, 2014 - 04:06 PM
yes ,this is for parts to complete my 8hp model. the engine is what intrigued me, briggs ? and the 2 pc hood/ grill area. that  bottom half should fit mine with the cast top piece.
#12 TomLGT195 OFFLINE
TomLGT195
  • 3,697 Thanks
  • 2,761 posts
Posted December 01, 2014 - 04:08 PM
I was thinking it was more like this one
Edited by TomLGT195, December 01, 2014 - 04:10 PM.
