What's Wrong With This Blower?
26 replies to this topic
#1 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted November 28, 2014 - 10:52 AM
Check out this video and pay attention to the blower and see if you can find anything wrong.
  • Cvans said thank you
#2 JDBrian OFFLINE
  • 9,655 Thanks
  • 14,162 posts
Posted November 28, 2014 - 11:12 AM
Looks like it's running backwards.
#3 bh115577 OFFLINE
bh115577
  • 443 Thanks
  • 240 posts
Posted November 28, 2014 - 11:19 AM
It almost looked like the impeller was turning backwards.
#4 Cat385B OFFLINE
    HAZMAT CAT
  • 14,455 Thanks
  • 10,184 posts
Posted November 28, 2014 - 11:27 AM
It is running backwards. The end of the video shows it running slowly. Try this trick to know why. Throw a tennis ball normally, like a baseball pitch. Then do with it resting in your palm only.
My goodness, hydraulic flow on a skidsteer is reversible, maybe his hydraulic pto is only built to run one way.
#5 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
I think the impeller is turning the direction it should for the orientation of the chute.
The auger looks to be pulling the snow into the impeller.
Edited by Username, November 28, 2014 - 11:30 AM.
#6 AfterShock95 OFFLINE
AfterShock95
  • 420 Thanks
  • 365 posts
Posted November 28, 2014 - 11:32 AM
I agree it's running backward try switching the hoses around to see if that helps it out any
Edited by AfterShock95, November 28, 2014 - 11:34 AM.
#7 hamman OFFLINE
hamman
    Homelite Owner Extraordinaire
  • 6,616 Thanks
  • 2,913 posts
Posted November 28, 2014 - 12:02 PM
When a snow blower is running properly ( two stage) it doesn't throw snow back out the front. At least the two I have had didn't. My single stage does but I have seen may SS do this. I agree that the secondary auger appears to be turning incorrectly. It should be turning clockwise instead of CCW.   Not sure but I think as Cat and others have said, might try reversing the lines to see if that helps.  JMUE2CW.        Roger
#8 Username OFFLINE
Username
  • 2,072 Thanks
  • 1,425 posts
Posted November 28, 2014 - 12:10 PM
If you changed direction,you would also change direction of the auger and it would be pushing show instead of pulling it in like it appears to be doing.
I think the paddles are bent in the wrong direction on the impeller.
Tractorgarden has a blower that has the paddles the wrong way and he will likely chime in about his blower.
  • mrmd said thank you
#9 Cat385B OFFLINE
    HAZMAT CAT
  • 14,455 Thanks
  • 10,184 posts
Posted November 28, 2014 - 12:13 PM
I would guess the roller chain that connects the first and second stage together (on the left side of the blower) is routed incorrectly, allowing it to turn the correct direction.
The snowblower in the video is made for a compact tractor. It is attached to a homemade A-frame, welded to a skidsteer mounting plate. It has a hydraulic motor 540 pto. In the video, when he shows the pto running, you can see it is running CCW. That's the wrong way, most SCUTs and CUTs run CW rotation.
  • Username said thank you
#10 Gtractor OFFLINE
Gtractor
    the homeless tractor hoarder
  • 9,955 Thanks
  • 5,145 posts
Posted November 28, 2014 - 12:46 PM
It'd be hard to change the direction on one auger with the chain drive.  It would almost have to have the gears backwards in a 90 degree gearbox to make them work opposite - much like turning the ring gear over to the other side in a differential to reverse direction of travel.
Didja notice the angle of the universal joint?   Wholly crap thats a bad design!!!!!!!  :(
#11 Lmiller3358 OFFLINE
Lmiller3358
  • 1,568 Thanks
  • 1,469 posts
Posted November 28, 2014 - 12:58 PM
I agree, it does look like it turning backwards, I wonder if the impeller was assembled backwards though ? Looks lke it needs be taken off the shaft and turned180 degrees !
#12 Lmiller3358 OFFLINE
Lmiller3358
  • 1,568 Thanks
  • 1,469 posts
Posted November 28, 2014 - 01:01 PM
On my second look , looks like it can only go one way though ! Could have been welded wrong from factory ....
#13 Enginerod OFFLINE
Enginerod
  • 245 Thanks
  • 294 posts
Posted November 28, 2014 - 01:05 PM
I have a feeling it is turning the correct direction, I think its an optical illusion like when you look at a spoked wheel and it looks like its turning backwards. If the auger is turning the correct direction I dont see how the impeller could be turning backwards. I think the snow getting thrown forward is from the plate he welded on the auger.
  • Gtractor said thank you
#14 Enginerod OFFLINE
Enginerod
  • 245 Thanks
  • 294 posts
Posted November 28, 2014 - 01:09 PM
Im thinking optical illusion because the secondary impeller seems to be turning too slow which is the case when that happens
  • olcowhand said thank you
#15 Sparky OFFLINE
Sparky
  • 1,298 Thanks
  • 1,892 posts
Posted November 28, 2014 - 01:38 PM
The old farm boy in me says the blades on the blower need to ditch the  " L " fold over in favor of slightly curved blades . Upon ejection of snow they pressurize with air an snow has a backpressure at that point in time . A little more rpm on the blower would help .
