* * * * * 1 votes
Cub Cadet 122 Independent Brakes
10 replies to this topic
#1 The Junk Doctor OFFLINE
The Junk Doctor
  • 31 Thanks
  • 30 posts
Posted November 25, 2014 - 07:47 PM
 For all you narrow frame Cub guys, I got an idea to make plowing easier than cuttin' butter. I took the disk brake assemblies off of a junk CC 1450 I had. I then made the linkages from all sorts of stock laying around the shed, and started cutting, welding, and bending. More info to come....IBCub#1.png IBCub#2.png IBCub#3.png IBCub#4.png IBCub#5.png IBCub#6.png
  • olcowhand, wvbuzzmaster, KennyP and 4 others have said thanks
#2 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted November 25, 2014 - 07:52 PM
It looks good. How low will the pedal mounts be when you lower the Jack?
  • The Junk Doctor said thank you
#3 The Junk Doctor OFFLINE
The Junk Doctor
  • 31 Thanks
  • 30 posts
Posted November 25, 2014 - 08:26 PM
Thanks! I'll measure tomorrow and let you know, but I made sure all implements would work with the hydro lift and all implements. I've already plowed with it too. :D
#4 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted November 25, 2014 - 09:36 PM
I like it, and need to do that to my cub cadet 102, as the internal brake is an absolute joke. I will definitely be taking notes.
#5 KennyP ONLINE
  • 40,023 Thanks
  • 46,722 posts
Posted November 26, 2014 - 05:10 AM
All I need on the 108 is the pedals and linkage as it already has the twin discs.
  • Alc and The Junk Doctor have said thanks
#6 Alc ONLINE
  • 7,112 Thanks
  • 7,526 posts
Posted November 26, 2014 - 06:27 AM
Kenny that seem strange that they would spent the money to put 2 discs on it and only one pedal ? Good for you though , was there other Cubs with twin discs ?
#7 KennyP ONLINE
  • 40,023 Thanks
  • 46,722 posts
Posted November 26, 2014 - 06:30 AM
I think all in the 'wide frame' series were, Al.
EDIT: all 86, 106, 107, 108, 109, 126, 127, 128, 129, 149, 784 (SN 720000 and up), 1250, 1450, 1650, and certain 800, 1000, & 1200 models.
Edited by KennyP, November 26, 2014 - 06:41 AM.
  • Alc, GTTinkerer and The Junk Doctor have said thanks
#8 The Junk Doctor OFFLINE
The Junk Doctor
  • 31 Thanks
  • 30 posts
Posted November 26, 2014 - 04:28 PM
The bottom of the brake pedal mounts sit about 9 3/4" above the ground. Also, I'm looking for the diagram I made to scan on the computer, but its lost in a pile of junk....... :wallbanging:
#9 The Junk Doctor OFFLINE
The Junk Doctor
  • 31 Thanks
  • 30 posts
Posted December 04, 2014 - 07:20 PM
Found the diagram! Will be posted as soon as I figure out this scanner.
#10 The Junk Doctor OFFLINE
The Junk Doctor
  • 31 Thanks
  • 30 posts
Posted December 16, 2014 - 06:44 PM
Sorry fellas, I got so caught up in the tests and essays that pour in before Christmas break. Hopefully I will get the diagram up and maybe try some editing for different models.
  • olcowhand said thank you
#11 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted June 29, 2015 - 12:57 AM
Any updates for us?
I just drug home a parts 109 to steal the brake stuff off of for the 102. Since I can't use some of the brake actuation linkage from hydro on gear, it might be something I look into making independant of the clutch.
