Sears Gt18 - Added To The Garage
53 replies to this topic
#16 Dpregs OFFLINE
Dpregs
  • 104 Thanks
  • 138 posts
Posted December 21, 2014 - 02:10 PM
Got more done on it today. Fixed the dash that was loose. Got the headlights working. And took it for a ride....and then I noticed that low gear is not engaging :(
#17 KennyP ONLINE
  • 40,961 Thanks
  • 47,139 posts
Posted December 21, 2014 - 02:14 PM
If I am correct, the shifter/shaft the lever hooks to on the tranny is out when in HI. I may have a layer of rust/crud on it keeping it from shifting.
#18 Dpregs OFFLINE
Dpregs
  • 104 Thanks
  • 138 posts
Posted December 21, 2014 - 02:55 PM
I'll give it a look. Also. ..any one mod the lights to leds? Or just pop leds on the hood?
#19 KennyP ONLINE
  • 40,961 Thanks
  • 47,139 posts
Posted December 21, 2014 - 03:34 PM
No mods on the lights I know of!
#20 Dpregs OFFLINE
Dpregs
  • 104 Thanks
  • 138 posts
Posted December 21, 2014 - 03:43 PM
well then....time to research using LEDs in replacement of regular bulbs.  I am sure there is no swap this for that....but we shall see.
#21 Dpregs OFFLINE
Dpregs
  • 104 Thanks
  • 138 posts
Posted December 21, 2014 - 08:21 PM
Tried to swap out bulbs with 1156 LEDs from autozone....no go, wouldn't even light. Regular 1156 bulbs worked no prob.
A few pics and a video of it running.
GT 18 running:
  • Cvans said thank you
#22 Cvans ONLINE
  • 7,304 Thanks
  • 6,388 posts
Posted December 21, 2014 - 08:46 PM
Sounds nice. Your is a little newer than mine. My hood gets narrower over the dash otherwise everything else pretty much looks the same. I didn't get a deck with mine either. It was purchased new with just the tiller.
#23 Dpregs OFFLINE
Dpregs
  • 104 Thanks
  • 138 posts
Posted December 21, 2014 - 08:52 PM
I have the deck. Took it off to make room for the plow. :)
#24 Dpregs OFFLINE
Dpregs
  • 104 Thanks
  • 138 posts
Posted December 22, 2014 - 07:31 AM
Another quick question:
Should the headlights get brighter or dimmer as the throttle is picked up/down?
My initial says no, bad regulator?
#25 KennyP ONLINE
  • 40,961 Thanks
  • 47,139 posts
Posted December 22, 2014 - 07:46 AM
At idle, there is not as much voltage being made. Speed it up and the voltage increases to a max of ~14.5 volts. So yes, the lights will get brighter as you increase the RPM's. Some of that depends on the battery too. A small battery will do this more than a larger battery.
I didn't get out back yesterday! Hopefully today will be better for looking for those parts.
  • Cvans and Sawdust have said thanks
#26 KennyP ONLINE
  • 40,961 Thanks
  • 47,139 posts
Posted December 22, 2014 - 04:12 PM
I think I have the mower lift links. I'll have to see if the part #'s are the same.
#27 KennyP ONLINE
  • 40,961 Thanks
  • 47,139 posts
Posted December 23, 2014 - 04:50 AM
I scrapped one Craftsman II a while back to use parts for the GT18. I may have those mower links on a shelf in the garage. They are the same part #, so I'll look there before I take any off the other tractors. I'll be out there today!
  • MH81, Cvans, Sawdust and 1 other said thanks
#28 Dpregs OFFLINE
Dpregs
  • 104 Thanks
  • 138 posts
Posted December 23, 2014 - 09:20 AM
You rock Kenny!
#29 Dpregs OFFLINE
Dpregs
  • 104 Thanks
  • 138 posts
Posted December 24, 2014 - 10:13 AM
Bob was able to help me out with the two linkages.
#30 KennyP ONLINE
  • 40,961 Thanks
  • 47,139 posts
Posted December 24, 2014 - 01:55 PM
Glad you could get them!
