Wheel Weights
41 replies to this topic
#31 Cat385B ONLINE
    HAZMAT CAT
  • 13,779 Thanks
  • 9,918 posts
Posted February 03, 2015 - 10:30 AM
6"? Long ways from the tower? Got a valve partially closed?
  • yquwaseb said thank you
#32 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted February 03, 2015 - 01:15 PM
12" with a hole in the side. Only about 1 mile from the tower. Makes things fun in the middle of snowstorm clean up.
We are averaging about one per day.
Geno
  • Cat385B said thank you
#33 Cat385B ONLINE
    HAZMAT CAT
  • 13,779 Thanks
  • 9,918 posts
Posted February 03, 2015 - 01:47 PM
That really ties into this thread well, Geno. All my lead I'm stockpiling are former water main gaskets.
  • bgkid2966 said thank you
#34 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted February 03, 2015 - 03:27 PM
My lead is from water services.
Geno
#35 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted February 04, 2015 - 12:53 PM
I am still trying to get my hands on some lead, seems around here it is getting hard to find. :wallbanging:
#36 Cat385B ONLINE
    HAZMAT CAT
  • 13,779 Thanks
  • 9,918 posts
Posted February 04, 2015 - 12:56 PM
It should be, it's a hazardous material.
And worth $$.
#37 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted February 04, 2015 - 02:37 PM
Naw!!  Its just heavy not hazardous :D
  • Cat385B, bgkid2966 and EricR have said thanks
#38 FixItCharlie OFFLINE
FixItCharlie
  • 518 Thanks
  • 335 posts
Posted February 07, 2015 - 10:23 AM
Not to hijack this forum but sometime ago I was ask about the wheel weights on my tractor.
At that time I did not know what the were just had found them in some stuff my dad had. They just fit the wheels good, had some weight to them,  look to be able to add weight by pouring lead in some openings.
 Recently I found out what they are. They are the mounts used on high voltage porcelain insulators used at power plants. My dad who worked at a power plant must have grabbed  them  from some broken insulators & may have planned to do the same thing. It is interesting sometimes what can be found & used for something totally different then its original purpose.
Charlie
  • MH81, KennyP and bgkid2966 have said thanks
#39 bgkid2966 OFFLINE
bgkid2966
  • 1,411 Thanks
  • 1,331 posts
Posted February 07, 2015 - 08:32 PM
How deep is the cavity? It looks like you could break out more of the porcelain and get more lead in too maximize the weight.
Geno
#40 FixItCharlie OFFLINE
FixItCharlie
  • 518 Thanks
  • 335 posts
Posted February 07, 2015 - 09:26 PM
I am sure several pounds can be placed in there & still leave space for the lug bolts. The porcelain that was chipped out was for clearance. When these are mounted in the wheels they make contact with the rim not the lug bolts. Before I put any lead there I will start filling the pockets on the other side. Right now I need to find the lead pot & ladle when we use to cast fishing weights & bullets. I am sure I will come across it one of these days or maybe my brother has it. I have had several other projects to work on right now & have not had any traction problem with the fluid filled tires & a weight box on the back when I am moving snow.
Charlie
#41 victor3ranger OFFLINE
victor3ranger
  • 314 Thanks
  • 630 posts
Posted February 09, 2015 - 11:48 AM
Charlie
Charlie,
I sure wish you could find some more of those :smilewink:
#42 AfterShock95 OFFLINE
AfterShock95
  • 420 Thanks
  • 365 posts
Posted February 24, 2015 - 09:19 AM
Couldn't you use an old rim for the mold just weld the holes around the outside shut put big bolts in the bolt holes and put something in the center hole if it had to stay open the way you wouldn't have to drill the lead out
