Wheel Weights
41 replies to this topic
#1 bgkid2966 OFFLINE
bgkid2966
  • 1,412 Thanks
  • 1,331 posts
Posted November 25, 2014 - 07:28 AM
Today is the day to pour the lead wheel weights for the 129. The turkey fryer will be hot as the lead melts, and then will be poured
into a springform baking pan. Hopefully it will work well. Pictures will follow as progress is made.
Geno
  • Cvans, Sawdust, Gabriel and 1 other said thanks
#2 KennyP ONLINE
  • 40,943 Thanks
  • 47,131 posts
Posted November 25, 2014 - 07:33 AM
Yes, pics will be a must here. What size weights are you going for? The ones I made for my Ford were 65 lbs. With the adapter, scaled right at 75 lbs. I used a cheap Stainless skillet from Wally World ($19.95) for the mold!
  • bgkid2966, superaben, Sawdust and 1 other said thanks
#3 bgkid2966 OFFLINE
bgkid2966
  • 1,412 Thanks
  • 1,331 posts
Posted November 25, 2014 - 07:39 AM
I have not figured out the weight of each yet. The springform pan is a cheap Walmart buy, under $10 I think. The weights will be stacked to fill the wheels and maybe a little out side. Kenny, did you melt the lead in the pan or did you pour it into the pan as a mold? I would love to be able to stop using the chains, though I don't think it is possible. The weights will also be helpful when the Johnny bucket gets mounted.
Geno
Edited by bgkid2966, November 25, 2014 - 07:40 AM.
#4 KennyP ONLINE
  • 40,943 Thanks
  • 47,131 posts
Posted November 25, 2014 - 07:45 AM
I melted directly in the pan as it has a thick bottom. I've got some pics on here some where. I'll see if I can find them.
Here's the thread. Post 78 shows the lead weights.
Edited by KennyP, November 25, 2014 - 07:57 AM.
  • bgkid2966 and GlenPettit have said thanks
#5 bgkid2966 OFFLINE
bgkid2966
  • 1,412 Thanks
  • 1,331 posts
Posted November 25, 2014 - 12:31 PM
Here is the first attempt. It is cooling. Hopefully the springform pan will come off easily.
Geno
  • sacsr, Cat385B, Sawdust and 1 other said thanks
#6 bgkid2966 OFFLINE
bgkid2966
  • 1,412 Thanks
  • 1,331 posts
Posted November 25, 2014 - 01:27 PM
First one out of the mold!
Geno
  • olcowhand, MH81, KennyP and 3 others have said thanks
#7 bgkid2966 OFFLINE
bgkid2966
  • 1,412 Thanks
  • 1,331 posts
Posted November 25, 2014 - 07:06 PM
So, the springform pan worked for 2 weights and then the third one did not want to come out. Tried number 4 and the pan leaked molten lead all over the
driveway. A quick trip to Wally World and $11 later the 4th weight is in a stainless steel frying pan. One of the first three will be melted to fit the pan. This will give
me 2 9" weights and at least 2 10" weights.
Here are pics of the first 2 on the scale.
These are lighter than I wanted, but the frying pan is going to be heavier. I will weigh the first one tomorrow.
Geno
  • wvbuzzmaster, Sawdust and Gabriel have said thanks
#8 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted November 25, 2014 - 07:29 PM
Are you sticking any 1/2 inch pipes in the pans for mounting holes or going to just drill them?
#9 KennyP ONLINE
  • 40,943 Thanks
  • 47,131 posts
Posted November 25, 2014 - 07:30 PM
Geno
I filled the pan pretty full to get the 65 pounders. They are close to 2" thick!
  • bgkid2966 and Sawdust have said thanks
#10 bgkid2966 OFFLINE
bgkid2966
  • 1,412 Thanks
  • 1,331 posts
Posted November 25, 2014 - 07:55 PM
I am just going to drill them.
The frying pan is a full 2" thick and the first bunch from the springform pan are about 1 3/8" thick and 9" diameter.
I am planning on 2 2" weights and 1 1" for each side.
Geno
Edited by bgkid2966, November 25, 2014 - 07:56 PM.
#11 bgkid2966 OFFLINE
bgkid2966
  • 1,412 Thanks
  • 1,331 posts
Posted November 26, 2014 - 11:06 PM
Here are the final weight pictures until they are mounted.
They just need to be drilled then installed. The last pic is of the pan set from Walmart and worked great.
P.S. Why do the pictures rotate when they are downloaded?
Geno
Edited by bgkid2966, November 26, 2014 - 11:08 PM.
  • Sawdust said thank you
#12 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted November 26, 2014 - 11:42 PM
That actually looks really good. Finding lead around here is the hard part.
  • bgkid2966 said thank you
#13 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted November 26, 2014 - 11:44 PM
What were those chunks of lead originally?
#14 bgkid2966 OFFLINE
bgkid2966
  • 1,412 Thanks
  • 1,331 posts
Posted November 26, 2014 - 11:45 PM
The lead is old water service lines that started leaking and were repaired with copper sections.
Geno
  • wvbuzzmaster and Sawdust have said thanks
#15 Sawdust OFFLINE
Sawdust
  • 6,154 Thanks
  • 3,548 posts
Posted November 26, 2014 - 11:52 PM
This is a great project & they look real nice. Will you be painting them to match your tractor? I get so mad at myself when I see molten lead. I had saved mostly the same old lead drain pipes along with other pieces. I took almost 100 lbs to the scrap yard only finding out two days later the US shut down the last smelting plant. Lead has sky rocketed since :(
