Repairing Voltage Reg. Mounting Tabs
7 replies to this topic
#1 Sawdust ONLINE
Sawdust
  • 5,638 Thanks
  • 3,358 posts
Posted November 23, 2014 - 07:24 PM
My VR worked fine but was almost hanging by a thread on my MTD 990 because of the rotted rubber mounting tabs.
I drilled out the old rivets & cleaned everything up to be repaired.
I cut two pieces of rubber off of an old tire.
I used 1/8" x 1/4" long pop rivets for the repair. The first rivet worked fine but the second one pulled itself through the hole. I drilled out the two rivets I just put in & started over  :mad2:  This time I just pulled the rivet enough to mushroom the head then stopped. I took the rivet gun off & clipped the remainder of the stem off, this worked fine.
All painted up & ready to go!
If you want to follow my rebuild you can see it here. Thanks!
http://gardentractor...d-up-a-mtd-990/
  • DH1, MFGray, hamman and 8 others have said thanks
#2 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Posted November 23, 2014 - 07:39 PM
Very nice work, Jim!
  • Sawdust said thank you
#3 Gabriel OFFLINE
Gabriel
  • 1,442 Thanks
  • 1,859 posts
Thanks for sharing!
#4 Moosetales OFFLINE
Moosetales
    Always learning something!
  • 1,088 Thanks
  • 1,284 posts
Posted November 23, 2014 - 08:20 PM
Jim,
Now you had to go and make your VR all neat and pretty. I was planning on leaving mine original but now you go me re-thinking my plan. You did a great job. Looks awesome.
  • Sawdust and Gabriel have said thanks
#5 dthomp17 OFFLINE
dthomp17
  • 587 Thanks
  • 472 posts
Posted November 23, 2014 - 08:23 PM
Good job, thanks for sharing.
#6 classic ONLINE
classic
  • 5,203 Thanks
  • 2,247 posts
Posted November 23, 2014 - 08:51 PM
Thanks for posting that, Jim. I have to do the same thing to the regulator on the Squire. Only one of the rubber mounts is intact, but the regulator works fine.
#7 Sawdust ONLINE
Sawdust
  • 5,638 Thanks
  • 3,358 posts
Posted November 23, 2014 - 09:22 PM
One of mine was ok too but I thought I might as well do both of them. I just couldn't put that rusty thing back on my freshly painted grill  :(
  • Moosetales, Gabriel and classic have said thanks
#8 MFGray OFFLINE
MFGray
  • 131 Thanks
  • 123 posts
Posted November 24, 2014 - 05:27 PM
Thanks for this - you posted it at just the right time for me. I have a regulator that is broken on both sides - I was looking for the right kind of rivet - now I know how to sort it out.
  • Moosetales, Sawdust and Gabriel have said thanks
