1972 Gt14
33 replies to this topic
#16 glgrumpy OFFLINE
  • 8,741 Thanks
  • 7,978 posts
Posted January 13, 2015 - 05:48 PM
Hey! where you live?   Can I get a good cheap price to buy this or both?  Heee! Heee!  Have to hit you when you're down for best deal you know!  If not near Indiana......"Never Mind".
#17 olcowhand ONLINE
  • 42,399 Thanks
  • 31,803 posts
Posted January 13, 2015 - 06:36 PM
He's near Georgetown, Ky, next to Lexington, Ky.
#18 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted January 13, 2015 - 08:35 PM
I won't be selling these any time soon. Spent too long trying to find one is decent shape. You all are just my venting people lol.
  • olcowhand, Texas Deere and Horse, twostep and 1 other said thanks
#19 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,643 Thanks
  • 1,318 posts
Posted January 13, 2015 - 08:56 PM
Well there goes that. I was getting in line for parts too,David. :poke: :smilewink:
#20 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted January 22, 2015 - 06:45 PM
I put another carb that I knew somewhat ran. At least I got her to run for more than a minute. Any body had any luck with those new cheap carbs on ebay?
#21 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted February 06, 2015 - 06:49 PM
I wonder if these really need a fuel pump? At least for running full throttle test in the shop?
#22 Rock farmer OFFLINE
Rock farmer
  • 1,234 Thanks
  • 1,246 posts
Posted February 11, 2015 - 06:57 PM
I know I'm a bit late. But, no you don't need a fuel pump.
You can use gravity feed. Just keep the tank higher than the carb.
As long as you don't have air in the line you should be fine.
Joe
#23 Racinbob OFFLINE
Racinbob
  • 76 Thanks
  • 68 posts
Posted February 13, 2015 - 09:14 AM
I haven't tried one personally but there was some talk about them on another forum and folks were happy with them.
#24 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted February 14, 2015 - 04:06 PM
Now the new fuel pump I put on isn't working.  Its like this wasn't ment to be.  I will soon order a new carb and new oem fuel pump.  New goal - Have it driving and mowing by March 15th.
#25 glgrumpy OFFLINE
  • 8,741 Thanks
  • 7,978 posts
Posted February 15, 2015 - 02:31 AM
B-farm, think the 14 hp takes a diff arm on the pump, maybe longer? to work. Check if you have same arm as old one on the new pump?  OR, don't some engines take the lever on opposite side of cam, like up on top or at bottom when mounted? Might check the lines between pump and carb. I know they are short, but have had those be plugged or leaking many times. AND, did you remember to turn on the tank's valve at bottom it it has one? Mine had one.
#26 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted February 28, 2015 - 10:15 PM
I had plans of this thread showing 3ph pictures and snow plowing pics by now.  Pictures of fixing the little things and pictures of it getting ready to mow/plow.  I'm tired of messing with this.  Something if wrong with the fuel system.  I ordered a new carb and a new fuel pump so wish me luck.  I really hope to have this thing running by next weekend.
I have been thinking about it and think I am going to remove the fuel tank.  I don't like its location and don't care for the looks of the air filter sticking out the side.  There is enough room to put the battery in the tank location and putting a tank where the battery is.  Where's the best place to get an aftermarket tank?  I need one about the size of a battery.
#27 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 14, 2015 - 02:28 PM
Finally got the new carb and fuel pump on.  It runs great but still has several loose ends I need to fix.  The belt tensioner is not working the right way and its throwing belts.
  • twostep, Rock farmer and Sawdust have said thanks
#28 Rock farmer OFFLINE
Rock farmer
  • 1,234 Thanks
  • 1,246 posts
Posted March 15, 2015 - 01:08 PM
On some of those wheelhorses, you need to have the belt cover on.
There may be tabs on the inside of the cover that keep the belt in place.
Joe
#29 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 15, 2015 - 07:36 PM
Joe
I actually thought about that after the fact.  That will be my next step but first Ive got to find a manual and look up the belt size.
#30 BairleaFarm OFFLINE
BairleaFarm
  • 1,354 Thanks
  • 1,783 posts
Posted March 21, 2015 - 09:25 PM
I haven't done much with the belt but I am thinking about the hitch. uploadfromtaptalk1426990934380.jpg
I've got a couple options. With a few different 3ph setups I have laying around here. uploadfromtaptalk1426991096319.jpg
