Adding power steering, what do I need?
35 replies to this topic
#31 jdslednut OFFLINE
jdslednut
  • 680 Thanks
  • 851 posts
Posted December 24, 2011 - 11:52 PM
Are there separate priority valves available to plumb in to make a 4 port work like a 5 port? Any common type of equipment one of these could be rescued from to make it work in a GT? Maybe they're a beast of a thing. I don't know and am just curious. Now I have grabbed my Dad's 4 port Char-Lynn from his "retired" Gleaner F combine. I was kind of thinking it would be pretty cool to have rescued this part of the combine I spent many hours in during my youth and put it in my 314 to help keep it alive as an organ donor. Plus - I'm really tight with the funds and would rather make something work I already have than pony up the dough and make the wife a little more unhappy.
#32 olcowhand ONLINE
  • 42,472 Thanks
  • 31,827 posts
Posted December 25, 2011 - 10:57 AM
Yes, you can buy priority valves as stand alone. I actually have 2 of them, but to be honest, I'm not sure if they would work, as I have no idea what their settings are.
#33 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted December 26, 2011 - 12:53 AM
If youre going off the 314 hydro a priority valve would be a waste. A priority valve is really to ensure that you have enough flow to the steering system to make it consistent, no matter the rpms of the engine/overall output of the pump
Hydro charge pump -> Lift valves -> Steering column -> Return
You will need to check the discplacement of the Char-Lynn column to make sure the it does not starve because the charge pump is only 3-4gpm
  • jdslednut said thank you
#34 jdslednut OFFLINE
jdslednut
  • 680 Thanks
  • 851 posts
Posted January 05, 2012 - 04:05 PM
How would I check the displacement of my pump(s)? Is there a chart with model numbers/types that indicate this information anywhere? Wouldn't want to go through a bunch of work just to find the thing starves.
#35 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted January 05, 2012 - 09:17 PM
Starving/cavitation may be a problem. I think the biggest problem with a column that has too big of a displacement is the steering will become very jerky because the amount of oil being dumped into the cylinder on a small(er) tractor may be too much
What is the model of the column you have? The combine one? I think like Daniel said you are best off with a JD column as they are cheap and easy to find
#36 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted January 06, 2012 - 04:18 AM
It would need to be a really big unit , as most rigs have either a seperate steering pump, or a priority valve, and in most cases they are only about 6 gpm max. Did the valve come off of something articulated ? Or did it have small steering wheels like ,say a MF 50 ?
